88 Pickup clunk in 4wd
Old Nov 23, 2010 | 05:23 PM
mrmorrison's Avatar
I have an 88 pickup that is still ifs and one day I was parked in a ditch at work and when i left, I put it in 4 low to climb out of the ditch and i heard a big clunk in the front end. I thought it was one of the cv shafts, but after replacing them, it still does it. It snowed quite a bit here and i discovered that my four wheel drive isn't working. I think it might be something in the diff. any ideas?
Old Nov 23, 2010 | 05:56 PM
J_yota22k's Avatar
Well if you hearing clunk's when in 4 low then it might be you'r diff for sure.. but i could be wrong though. I would take it a part might be something crack in side..
Old Nov 23, 2010 | 06:27 PM
mrmorrison's Avatar
Its not just in 4 low, its whenever the hubs are locked and the t case is in 4wd. Super frustrating.
Old Nov 23, 2010 | 07:28 PM
94playtoy v6's Avatar
sounds like the t bars they all do it
Old Nov 23, 2010 | 07:30 PM
peow130's Avatar
I would definitely jack up the front of the truck and inspect your hubs, CV's, and well being of your front diff.
Torsion bars don't "clunk" in 4wd..
Old Nov 23, 2010 | 08:04 PM
mrmorrison's Avatar
I know that it isn't the t bars, because they have always been cranked since I have had the truck. Also, it only happens in four wheel drive.
Old Nov 23, 2010 | 08:07 PM
Tanker5503's Avatar
does it feel like a dragging tire/clunkin when in 4wd. my 3.0 xfer case chain had stretched and was causing it. just my 2 cents with a problem i had after replacing 2 CV's and taking apart the diff
Old Nov 23, 2010 | 10:17 PM
peow130's Avatar
88 doesn't have a chain driven Tcase, it's a gear drive so that wouldnt be the issue.
Again, have you jacked up the front of the truck and started wiggling parts?
Old Nov 27, 2010 | 09:16 PM
mrmorrison's Avatar
So I still had all the IFS stuff i cut off of my other truck, and i swapped out the diff and both cv shafts and the noise is gone and four wheel drive works again. Thanks for all the help. Now i can enjoy the snow!
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
TokyoD23
Jul 12, 2015 06:01 AM
Roger Borba II
Jul 9, 2015 05:05 PM
cyclist231
Jul 7, 2015 12:56 PM
