Possible blown HG, head shave required?
Old Nov 30, 2010 | 10:49 AM
threadlock3d's Avatar
I suspect i have a bad HG, when I run the motor without the radiator cap , bubbles appear after it gets to temp, but only after I press the throttle.
I want to do the job myself, but want to know if I should shave the head if it hasnt overheated.
any thoughts?
Old Nov 30, 2010 | 11:02 AM
xxxtreme22r's Avatar
you cannot tell by looking at text on a thread, nor can you accurately tell by seeing a photo, only way you can tell for sure is to give your head to a qualified machine shop to check for straightness.
A head can warp even if it is not overheated.
You also have issues of the head and/or block pitting. So sometimes like in the case of my rebuild, I had to have the block shaved because of the mostly the inability to get an actuate ridge ream after boring out the motor, and instead of doing a valve job etc etc I just went with a brand new assembled head.
Old Nov 30, 2010 | 11:40 AM
TNRabbit's Avatar
Do you have any other symptoms? Is it overheating? I would do a coolant system pressure test before tearing anything down...
Old Nov 30, 2010 | 12:16 PM
vital22re's Avatar
totally a bro
peanut butter under the oil cap? a bunch of white smoke out of the exhuast? what vehicle? year? motor?
Old Nov 30, 2010 | 01:11 PM
its a 92 22re with 235xxx, no other symptoms--I had two honda civic HGs blow on me and I replaced them both myself, but this little guy isnt showing any of those symptoms--no smoke or cloudy oil, just loping idle at times...
When I first turn it on, the temp gauge might max out for 10 to 15 seconds and then drop to a little over 1/3
I lose alot of coolant and have not seen external leaks anywhere, it gets pushed out into the overflow tank--
I tried pulling each plug wire while it was running and the piston second to the front didnt mind that i just cut the spark, so i wonder if the leak is there...
Old Nov 30, 2010 | 01:14 PM
i replaced the tstat with a 195 degree tstat, put a new 13 pound rad cap on--but the radiator is off a pre 86 toyota so its not stock...
Old Nov 30, 2010 | 04:33 PM
I dont know what a pressure test is, or how to do it...i have been debating whether i should pull the head, and i dont want to, so if their is a way i can rule it out i would do that...but i was thinking it would be a good time to look at the valves...sounds like an industrial sewing machine...
thanks for the suggestion
Old Nov 30, 2010 | 05:15 PM
vital22re's Avatar
totally a bro
well get a compression checker... it threads into the spark plug hole.. While you're at it. pull all the plugs and take pictures of them. How do they look? Get a coolant pressure checker. It sits in place of the radiator cap and with it you can pressure up the coolant system to see where leaks are.
Flossy
Aug 5, 2015 05:14 PM
toofly1999
Jul 25, 2015 07:09 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
