'91 3.0 idle issues
Old Nov 26, 2010 | 09:33 AM
mt4runner's Avatar
'91 3.0 idle issues
During the last couple of months, the idle speed on my 4runner has been slowly increasing. This is apparent at cold start and continueing at operating temperatures. At cold start, it used to idle at 1200-1400 rpm, and settle down to 600. Now cold start is 1700-1800 and warm idle is 900-1000.
Any ideas as to where to start looking would be appreciated.
Regards, Rick
Old Nov 26, 2010 | 11:22 AM
Wheelingnoob's Avatar
I'm having a similar problem but mine is at 200rpm all the time. If I turn it off and start it when hot it will hold a good 800rpm idle till I hit the gas if I hit the gas right back to a 2000rpm idle. I'm going to look at the TPS and the throttle to see if its sticking, also going to look at the dash pot as well.
Old Nov 26, 2010 | 11:57 AM
Fishaa's Avatar
I just asked this question in another thread. Everyone was suggesting the IAC Valve (Idle Air Control) and to check that your coolant level is topped up. Mine wasnt quite full and i topped it up and it sorta went away but it also got much warmer here so I still think its this IACV
https://www.yotatech.com/forums/f116...ps-set-224525/
Old Nov 26, 2010 | 01:47 PM
sb5walker's Avatar
Since your idle speed is dropping when the motor gets hot, the AAV is working. Suggest looking for vac leaks with an unlit propane torch or starting ether, listening for increase in idle speed. You have tried adjusting the idle speed screw, right? BTW hot idle on a 3VZE should be 800.
Vac leaks can be tough to locate. You have to check all vac tubes/hoses and joints in the throttle body/plenum/intake manifold, including brake booster & PCV hoses.
Old Nov 26, 2010 | 06:18 PM
mt4runner's Avatar
sb5walker, I havn't tried adjusting the idle screw yet, can't see how it would slowly come out of adjustment like this. If the throttle plate (butterflys?) is dirty and not resting at the correct position at idle, would that cause this issue? Would it fool the IAC and cause it to give more throttle at cold start than normal?
Rick
Old Nov 26, 2010 | 06:50 PM
sb5walker's Avatar
If the o-ring around the throttle adjust screw was old, and it dried out and shrunk, then vibration can cause the screw to move. In which case a new o-ring is in order - get one from any auto parts store. Doesn't have to be any exact size, just one to fit the screw.
I guess a filthy throttle plate could affect idle speed, if there were enough gunk to keep it from closing. Good to check. It's not going to "fool" the cold idle up valve, there's nothing to "fool". The AAV is just a thermostat-like valve that closes the cold idle air bypass when hot coolant hits it. Since idle speed is going down when the motor gets hot, like it should be, it sounds like the AAV is closing just fine.
Old Nov 26, 2010 | 07:34 PM
mt4runner's Avatar
Just went out and tried looking for the idle adjustment screw. I could only find a couple of screws that I would call Idle stop screws. No rubber o-ring, just a lock nut w/yellow paint showing me that at least these two screws havn't moved. Where is the idle speed adjustment screw located?
Old Nov 26, 2010 | 07:41 PM
sb5walker's Avatar
A forum search of '3vze idle screw' gave this thread: https://www.yotatech.com/forums/f116...-screw-196596/
The stop screw should never be adjusted.
Old Nov 26, 2010 | 09:03 PM
mt4runner's Avatar
Thanks, I'll check it out.
Old Nov 27, 2010 | 04:39 PM
mt4runner's Avatar
Had to go to town today(40 mi.) and it idled fine, both at start-up and after it warmed up. Go figure. Did a vacume leak test, nothing happening there. So I guess I will test the IAC and TPS and make sure they are in spec. sb5walker, if the o-ring were bad on the idle screw, wouldn't that be a potential vacume leak as well? I'm kind of ruling that out seeing how it idled fine today.
Rick
Old Nov 27, 2010 | 05:00 PM
sb5walker's Avatar
Yes, the idle screw could cause a very small vac leak, but probably not enough to notice.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
ZONAYODA
Jul 13, 2015 07:17 PM
Coreyr384
Jul 10, 2015 11:13 AM
