3.0 staggering
Old Jun 16, 2009 | 04:02 PM
cr250rgio's Avatar
3.0 staggering
Hey everyone, so i just bought a 1991 ex cab 4x4 with the 3.0 and every once in a while in third and fourth gear between 2000 and 3000 rpm it will stagger until 3100 rpm and then it will go away for a while. I was going to change the plugs wires and cap but from reading around this doesn't seem to fix the problem, alot of people say its their TPI can someone explain this to me.
thanks
Old Jun 16, 2009 | 10:30 PM
TNRabbit's Avatar
Do you mean TPS (Throttle Position Sensor)? I'd check for any engine codes FIRST.
Old Jun 18, 2009 | 08:34 AM
cr250rgio's Avatar
Thanks I'll check the codes and tell you guys whats up
Old Jun 18, 2009 | 09:49 AM
cr250rgio's Avatar
So I checked the codes and it came up with the standard one saying nothing is wrong could this just mean I should just change my dist. cap plugs and wires
Old Jun 18, 2009 | 10:48 AM
TNRabbit's Avatar
Is that the ONLY symptom you have?
A good tune-up is of course a good start. How long since the last one? How many miles on the engine? Has the O2 sensor ever been replaced?
Old Jun 18, 2009 | 01:46 PM
cr250rgio's Avatar
So far thats the only symptom concerning the Engine/tranny. Every once in a while it will stagger while accelerating and then around 3100 it will shoot off.It has about 179,000 miles and it doesnt look like the O2 sensor has ever been changed.
The only other problem is that the steering wheel shakes sometime when I brake, I looked at the steering and it looks like the bushings on the idler arm are worn out. Not sure when its had its last tune up but i am bringing it in for one in the next couple of weeks.
Old Jun 19, 2009 | 05:14 AM
Azabache's Avatar
Hey, I had the same steering problem when braking, the discs where bad
Old Jun 19, 2009 | 05:57 AM
Team420's Avatar
lots of things can cause shaking during braking, bj's, tierods, idler arm, bad rotors, etc
Old Jun 27, 2009 | 08:47 AM
cr250rgio's Avatar
So it turned out to be a bad O2 sensor and all of the problems seemed to have gone away after we installed the new one
Old Jun 27, 2009 | 09:29 AM
BeMiceElf's Avatar
Thanks! I have been having the same problem for a while and have been looking for a solution. Thanks you for the information.
Old Jun 28, 2009 | 12:15 AM
narts's Avatar
i had a similar problem. my truck i bought used to runn great during the day. but at night it would miss like crazy. so i figured out that at night when it misses, i turned off the lights and it would purr. came to find out that the ground wire from the battery terminal to the inside of fender was hanging by like 1 strand. replaced it and i was good 2 go!
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
