cooling system corrosion
Old Jun 23, 2009 | 05:06 PM
machine23's Avatar
im finding large deposits of corrosion around the inside of some cooling system parts. i know this is from regular tap water. but does anyone have a good method of getting this stuff out? maybe like something i could let the parts soak in?
Old Jun 23, 2009 | 06:15 PM
jackwolf's Avatar
Jackwolf
Want to experiment? I was thinking about setting this up after my bare metal project on the 2runner (2nd generation). There are two steps.
step one: Harris International Labs product
http://www.evaporust.com/evaporustcsc.html
step two: Cortec Corporation product
http://www.rustbloc.com/cgi-bin/dept?dpt=H&srch=BD
Evaporust rust remover has made it to my, hard to get on, RECOMMEND list. I have tried it and it works well. I have not tried the radiator flush but I have added it to my TRY list.
I have not tried any of the BullFrog products but they come highly recommended. They are on my TRY list.
I would go for two sessions with the evaporust and then follow up with the BullFrog*
*The only research I still need to conduct is what coolant/antifreeze to go with. I'm looking at a Shell-Lubricants product, Rotella ELC sourced from SOPUS Products :
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
...buts thats just a starting point for my research log.
Old Jun 23, 2009 | 06:19 PM
iamsuperbleeder's Avatar
JUST KIDDING... unless that really works...
Old Jun 23, 2009 | 06:27 PM
myyota's Avatar
If you have alot of corrosion then the best thing to do is pull the radiator and take it to a shop and have it cleaned out, replace the water pump and thermostat and you should be alright after that.
Old Jun 23, 2009 | 06:33 PM
I would just assume replace the rad for the $110 (+ - $20) it cost for an OEM style replacement...
Old Jun 23, 2009 | 06:58 PM
myyota's Avatar
True, there not that much and it probably cost as much to have it cleaned out at a radiator shop as to replace it.
Old Jun 23, 2009 | 07:01 PM
machine23's Avatar
my radiator is clean. the parts i am referring to are my water inlet pieces and some other areas around the water jacket in the lower intake manifold
Old Jun 23, 2009 | 07:55 PM
Jay351's Avatar
Flush it with water and refill with a 50/50 mix of distilled water (if the water is hard in your area) and toyota red or pink coolant.
Old Jun 24, 2009 | 12:30 AM
abecedarian's Avatar
The water jacket(S) in the lower intake are a return to the radiator via the thermostat and the supply to the heater.
If you've got mild deposits building up, a cooling system flush may take care of it. If it's severe, then more aggressive cleaning is needed... and that might mean several coolant flushes....
Nevermind... just realized it's a 3VZE... similar concept but I'm not an authority on the V6
Ktm526
Oct 7, 2015 05:14 AM
shalom
Sep 8, 2015 10:02 PM
some drunk guy
Sep 4, 2015 11:55 PM
128keaton
Sep 3, 2015 05:09 PM
moparbay
Sep 3, 2015 12:48 PM
