95 4Runner Leaning
Old Jun 11, 2007 | 01:46 AM
asmallwood's Avatar
95 4Runner Leaning
So I was parked next to another 4Runner the other day and just noticed what I guess several people have noticed before, my 4runner is leaning to the passenger side. I got out my tapew measure and took it to level ground and found out the the Passenger side is actually 3/4 of an inch lower than the driver's side. About two years ago the passenger side was in an accident and most of it was replaced (incuding Suspension). If this were my explorer I was just torque down the torsion bar a little assuming it was the cause, but what can you do on a 4Runner. Please Advise.
Thanks in advance for any help you can give me.
Aaron
Old Jun 11, 2007 | 01:59 AM
ChickenLover's Avatar
The stock suspension is pretty soft. The added weight of the gas tank (which is on the passenger side) can be enough to put a lean on your truck. Were both your front and rear passenger wheels 3/4" lower than the driver's side? If it was just the front, you can crank the passenger side torsion bar up 3/4", easily.
Old Jun 11, 2007 | 03:51 AM
asmallwood's Avatar
No it was both front and rearand strangely enough 3/4 of an inch on both, never thought about the gas tank though, that is a good point, I have to look and see if it was full.
Thank you
Aaron
Old Jun 11, 2007 | 04:43 AM
bigtrucknwheels's Avatar
i dont think its all the gas tank. my truck leaned to the right no matter if it had gas or not. but mine was mainly the front. i had a little over an inch or so in difference. crank on the torsion bar a bit, careful though. i had mine done at the toyota dealer when i had my ball joint replaced. the truck now sits almost perfectly level. and yes, it leaned to the right as well. here is how you do it...
http://toyota.off-road.com/toyota/ar....jsp?id=398514
Clicky^^^ Clicky!
hope this helps
Flying91
45
Apr 11, 2024 04:39 PM
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Doug4320
Mar 24, 2018 10:11 PM
BeMiceElf
Oct 10, 2015 09:40 PM
