Any specific year for 3.0 block?
Old Jun 14, 2007 | 11:11 AM
Stomis's Avatar
Well I used to do SBC's and I know that there were differences in the years despight them being the same general motor. Is there any optimal year to get my junkyard 3.0 like one with better valves from 91-94 or anything like that?
Old Jun 14, 2007 | 11:13 AM
Jay351's Avatar
I belive the only differance where the different hg used in the earlier years ( 88-89 or somthing like that)
Old Jun 14, 2007 | 11:18 AM
gilby4runner's Avatar
wasn't there a difference in the timing belt tensioner after a certain year? Not sure that makes any difference...
Old Jun 14, 2007 | 11:37 AM
Stomis's Avatar
Those are the kinda things I mean. Basically whats the best year to pull my donor motor from?
Old Jun 14, 2007 | 11:52 AM
To be honest i have little experience with the 3.0. I have worked on the 22re and 3.4. I would imagine that you would want a newer engine. While its out i would go ahead and do a little preventative maint. HG, Water pump, belt, ect. I would think the newer the better
Old Jun 14, 2007 | 12:25 PM
ScubaDuck's Avatar
From my unscientific monitoring here... As stated above, it seems 1989 and earlier motors don't have nearly the hg problems that the '91+ motors do. '89 was not part of the HG recall, (but Toyota extended the warranty, just to be safe).
If it were me, I'd go for an '89 or earlier. Mine still runs strong on the original HG (knocking on wood).
Good luck-
-Scubaduck
Old Jun 14, 2007 | 12:38 PM
snap-on's Avatar
the timming belt tensioner is a function of the fan bracket you put on the block, there is no casting diff.
THe blocks are the same for all 3vz* blocks.
There are diffrences in the water distubution block that bolts on the lower intake at the back of the motor, throttle boddy, type of injectors, distubutor type.... based on year, and options and make (4runner/truck/T100).
but block, pistions, crank, are all the same. (heads are diffrent on 3vz-fe)
this is why even though you can buy a long block, its recomended that you strip it down to a short block and transfer over all your acccessories that came on your truck as they will be correct.
Old Jun 14, 2007 | 03:37 PM
Stomis's Avatar
Ah so! Alright I'll definatly look into doing that. Save me a few bills in the mean time.
PS: Recommended company for a remanufactured shortblock?
Old Jun 14, 2007 | 03:50 PM
SEAIRESCUE's Avatar
88-89 Used different heads for the early model belt tensioner.
Old Jun 14, 2007 | 03:57 PM
881stGenRunner's Avatar
i would also go with a 88-89 block, im still running the original HG at 215000. They seem to be the best ones to go with.
Old Jun 14, 2007 | 04:10 PM
Stomis's Avatar
Hmmm anyone seen this I found searching on EBAY?
http://cgi.ebay.com/ebaymotors/TOYOT...6127QQtcZphoto
210ft/lb's is ok in my book! Wonder if it need super gas. Has a 7 year warranty though!
Old Jun 14, 2007 | 04:15 PM
hmm me like that longblock.
Old Jun 14, 2007 | 04:16 PM
Stomis's Avatar
Yeah right for the 2 grand I think I'm gonna go for it just because of the warranty. Even if I build a motor and save $500 if I toast another bearing I've got nothing to fall back on like this deal.
Old Jun 14, 2007 | 04:18 PM
it even has a $500 refundable core deposit. FOr $1500 thats not too shabby
Old Jun 14, 2007 | 04:24 PM
funjumper's Avatar
The core deposit is in addition to the purchase price.
Has anyone done business with these folks? Anyone checked their BBB ratings?
Old Jun 14, 2007 | 04:39 PM
Ahh my bad, sorry bout that. I never really understood the whole core thing til now. Thanks
Old Jun 14, 2007 | 04:56 PM
ernest t bass's Avatar
im suspicious
why would you want a torque peak at 4800 rpm or is that a typo.
i believe stock is 150 hp at 4800 and 180 lbft at 3400
Old Jun 14, 2007 | 05:00 PM
Stomis's Avatar
Honestly I think its cause of the way the motor is. Its hard to build it for a good curve from what I've read. Thats still gotta be at least 170-180ft/lb's of torque around 2500rpms.
Old Jun 14, 2007 | 05:15 PM
ShortyzKustomz's Avatar
Well the torque thing could all be in the motor, Im used to SBCs but I know on my 355 in my Camaro, My torque peak was like 386ft/lbs at 3200 RPM where as the stock 305 had a higher rpm torque peak
Old Jun 14, 2007 | 05:21 PM
justinking060310's Avatar
you could build a brand new shortblock from EB for like 350 bucks plus whatever a block+machine work would cost....
That would leave a lot of money for head work(IE cams at 350, exhaust/intake valves at 200)
You would be at those same power numbers or better by doing it yourself and not having some jimbronie building your motor. I would PM both sea2skytuning(Johnny w cams) and ENGNBLDR (Ted at enginebuilder) and ask them about your goals.... They will be very informative
