wont drive in second...uphill
Old Jan 7, 2010 | 08:20 PM
iPirate's Avatar
so i have a 93 4wd pickup with a 22re engine.
i did some work on it recently and now it's running fine...downhill. uphill, it runs good but only in first gear...as soon as i shift into second it starts to splutter, buck and die...if i don't downshift again.
any help greatly appreciated.
Old Jan 8, 2010 | 11:15 AM
weaselman's Avatar
check timing... what work did yoiu do??
Old Jan 8, 2010 | 11:39 AM
iPirate's Avatar
Timing chain, the whole deal(guides, tensioner, etc...). Adjusted the valves, Welded an exhaust leak, and a new PCV valve.
i havent been able to get the timing perfect. for some reason no one has a timing light, even the local Napa dosent stock them anymore.
Old Jan 8, 2010 | 11:47 AM
alfio's Avatar
sounds like ECM is running in survival mode - check timing, wires, etc.
Old Jan 8, 2010 | 05:37 PM
weaselman's Avatar
most likely a timing issue..
Old Jan 13, 2010 | 06:33 PM
iPirate's Avatar
so i got my timing light in the mail today. set it to 5BTDC...it still is misfiring really bad.
Old Jan 13, 2010 | 07:40 PM
874runnersr5's Avatar
hmm.. any reason you placed the timingchain? besides normal maintence?
Old Jan 14, 2010 | 06:08 PM
iPirate's Avatar
it wasnt running to well before...and the chain had never been replaced.
i think it might be a fuel problem
my next step is to check the fuel filter and pressure regulator.
any other suggestions or ideas on what it could be?
jasonty
41
Dec 23, 2018 01:00 PM
Tykiller1994
Aug 10, 2015 07:49 PM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
