Anyone Rockin 5.29's with 31's?
Old Jan 6, 2010 | 09:02 AM
90runnerfan's Avatar
just like the title says, just wonderin if anyone has it, or has done it, im movin from so cal to oregon and am concerned bout the cajon pass on the 5 dont think my stock gearin and loaded down will do to well. i was just gonna do the rear for now and pull the front drive shaft. thanks in advance
Old Jan 6, 2010 | 09:05 AM
Lumpy's Avatar
I think that's a bit low for 31's...I think you'll be revin quite high in the R's. Do you have a 5spd or auto?
Old Jan 6, 2010 | 09:06 AM
auto overdrive, i was on randys and it said it should be near 2207 at 55 and really thats as fast as i drive like an ol' lady
Old Jan 6, 2010 | 12:24 PM
OutlawMike's Avatar
I run 5.29's with 33 x 10.5's, also an auto rig, I have the 3.0.
At 65 miles per hour on the freeway I am spinning about 2600 RPM. I would not want to be any higher than that. I am about 13% lower geared than I was with 28.5" tires and 4.10's.
In town, my gas mileage dropped way off, partly due to the gearing and partly due to the extra weight of the bigger tires and steel wheels.
You could do it, but it would tach pretty darn high at freeway speeds on I-5.
If you are looking at going to 33's down the road, then you would not be wasting anything, as you will want the 5.29's with 33's in an auto rig.
Old Jan 6, 2010 | 12:50 PM
qdude79's Avatar
Here! See sig...
Old Jan 6, 2010 | 12:53 PM
thedanned's Avatar
Originally Posted by qdude79
Here! See sig...
I donut get it
Old Jan 6, 2010 | 01:10 PM
clk_cpa's Avatar
I have 5.29's with 265/75/16 which is little less than 32". Its fine. The truck actually loves the gearing considering its an auto. The RPM is around 3-3.2K when driving 65-70mph
Old Jan 6, 2010 | 01:30 PM
Dingman's Avatar
I've been running 36" SX's on 5.29's with a 22re\Auto.
2K at 55-60 (I think, never checked it with a GPS)
Honestly, I can't imagine 31's on it now, it would shift out of first gear in within 10 feet of starting. Way to low, even with an auto, IMO
Old Jan 6, 2010 | 01:33 PM
highonpottery's Avatar
I dunno man, 5.29s and 31's might not be a great choice when it comes to long stretches of flat hwy driving, but then again you've got an auto w/overdrive so your RPMs will be slightly lower than us 5spd guys.
I run 4.88s with 31s and at 60-65mph (reads about 65-70mph), my RPMs are around 3300 with a 5spd. At 70mph (reads 78ish), i'm at 3500rpms I'd guess that you'd be around 3500rpms going 65mph down I-5 with 5.29s and 31s. It will definitely help you out in the mountain passes, but on the flats you may regret it. If you drive like a grandma you might be ok, but when the speed limit is 70.....
Depending on how much of a load you've got, I'd stay with your 4.10s and take I-15 toward Bakersfield, then cut back over to I-5 for the rest of the way. From what I remember, the grades weren't as steep on that side. Going through the mtn. passes from Shasta up to Portland might give you trouble though, but definitely doable.
I used to take my old '87 yota 22ret 4wd x-cab 5spd 4.10s and a camper shell, up/down I-5 all the time loaded down with about 1000lbs worth of crap when I was still in college. It was a dog in the hills, but made it through just alright. I had some trouble with my clutch not grabbing well after it heated up in uphill LA/Valencia traffic.
If you do decide to put in the gears in just the rear, you don't have to pull the front driveshaft, just don't put it into 4wd and you should be good to go.
Old Jan 6, 2010 | 02:19 PM
crolison's Avatar
Hand's down with the auto do 5.29's.
I got 5.29's in my 2.7 with 33's and I love it.
Old Jan 6, 2010 | 02:41 PM
stroM-'s Avatar
Im running 5.29's with 35/12.50/15's. It does really well for me!
Old Jan 6, 2010 | 02:45 PM
PirateMcgee's Avatar
where in Oregon did you move?
Klamath falls by chance?
Old Jan 6, 2010 | 02:47 PM
ZUK's Avatar
ZUK
I ran that combo on my 88 Runner V6 auto 31" 529 gears. I was just fine with it...even on the highway. 70 mph was just over 3000rpm I think. And the cruise had no trouble holding it...no downshifting all the time.
I also had an 87 Runner(at the same time as the 88) it had the 22RE auto 33x10.50" 571 gears. It ran within about 1% of the overall gearing as the 88 model. That 22RE really appreciated the gear/tire combo. I remember that 3400 rpm equals 75 real mph.
It's the same combos I would run when I get my next Runner.
If you are worried about mountain passes and towing some stuff then 529 sounds like what you need.
ZUK
Old Jan 6, 2010 | 03:44 PM
whoa, thanks for all your guys input sounds like everyone has had pretty good luck with em. been dealin with a failed smog today on my runner, bummer. anyways pirate its redmond just outside of bend, should be movin in the next month or so. thanks
Old Jan 6, 2010 | 04:15 PM
stormin94's Avatar
I wouldn't gear that low for just one pass. Just think, you've gotta drive the rest of the freeway, which is mostly level( at least in the valley), and you'd be pushing the RPM's pretty high, and possibly committing MPG suicide. Not to mention the added stress of higher RPMs for long periods of time.
Old Jan 6, 2010 | 09:47 PM
sweet you'll love it up here! Bend area is awesome......I was asking because there's a 4runner that looks exactly like yours here at OIT in K-falls.
YotaLogic
12
Nov 17, 2015 06:27 AM
toyotasaurus
Sep 24, 2015 03:30 PM
justdifferentials
Sep 5, 2015 06:52 PM
coffey50
Jul 28, 2015 10:55 AM
