power steering hose - pump to reservoir
Old Jan 6, 2010 | 02:21 PM
iamsuperbleeder's Avatar
Hey fella's, I noticed the other day that I've got a hose that looks like it's about to let loose; it's swelling, and starting to seep a little...
It's the fluid return hose coming from the pump and up to the reservoir; the big one that's like 1/2" in diameter.
Anyone ever been able to get one outside of the dealership?
I know the dealer's probably going to be the best one I can get, but geez, $40 for that little 1ft long hose with 2 curves in it? comon...
Old Jan 6, 2010 | 02:58 PM
waskillywabbit's Avatar
Local parts store. Take yours and match one.
Old Jan 6, 2010 | 03:50 PM
bugs1961's Avatar
Toyota of Dallas has it for $30.03 if you can't find it locally.
Old Jan 6, 2010 | 04:23 PM
InternetRoadkill's Avatar
I used heater hose.
Old Jan 6, 2010 | 04:26 PM
abeD85flatbed's Avatar
why not simply replace it with just any hose with the appropriate inner diameter? The funny bend in the middle of the stock hose certainly shouldn't be a deal breaker when it comes to fitment.
Old Jan 6, 2010 | 04:50 PM
shaeff's Avatar
Originally Posted by InternetRoadkill
I used heater hose.
Bad idea. Heater hose is not designed for use with oil, (ATF) which will bloat the heater hose and eventually leak again- likely much more quickly than the OEM hose went.
It has to be a hose designed for use with oil, not just any hose.
Old Jan 6, 2010 | 04:57 PM
Did you notice the price of the pressure hose? 369.06! bought one about ten years ago for 15$ from checker and its worked great. It's still on the vehicle. If you can get the pressure hose after market, someone will carry a replacement for the return line.
Old Jan 6, 2010 | 05:11 PM
yeah I put a replacement pressure hose on it when I did the motor; it had actually split and was dripping down onto the frame
and yeah I know that heater hose wont work I've seen people use that for trans cooler lines before... didn't last a week, LMAO
I'm going to call the local dealer tomorrow and see what their cost is; I just looked this up and seen that price...
I REALLY want to get it replaced ASAP before it bursts and sprays ATF all over my hot header
Old Jan 6, 2010 | 05:43 PM
dntsdad's Avatar
https://www.yotatech.com/forums/f189/
Classified section here. tons of those being parted out
Old Jan 6, 2010 | 06:10 PM
Beaniam's Avatar
I used heater core hose, they last about a year before needing replacement.
Old Jan 6, 2010 | 06:13 PM
Considering the OEM hose lasted what...20 years? Spend the money get the proper hose.
Old Jan 6, 2010 | 06:15 PM
abecedarian's Avatar
So it's the hose that supplies fluid to the pump? It's not under any significant pressure so using an appropriately rated hose should be fine.
The only one that sees high pressure is the one from the pump to the steering box.
Colington
Mar 8, 2020 09:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jon.r
Jul 11, 2015 03:34 PM
Poncho0206
Jul 10, 2015 06:21 PM
skoti89
Jul 8, 2015 12:05 AM
