timing belt mistake
Old Jan 8, 2010 | 04:43 PM
tonyv57's Avatar
timing belt mistake
Hello Yota
I'm new, Glad to be aboard. I have a '92' V6 3.0 4runner. Have a bad water pump so I had to get into the timing belt. I made a mistake and took off the tensioner first and the cam pulleys moved so now the markings on the pulleys don't jive when i'm at TDC. how do I fix this rookie mistake or can I?
Thanks Tony
Old Jan 8, 2010 | 06:25 PM
bugs1961's Avatar
Welcome to the forum!
If the belt is still off the engine, you can just turn the pulleys with a 17mm wrench on the pulley bolt and line up the marks. If the belt is back on...bummer. You will have to remove the belt, align all three pulleys and reinstall the belt.
By the way, if the timing belt got antifreeze on it you should replace it. Antifreeze or oil on the belt will weaken the rubber and lead to a premature failure.
Download the Factory Service Manual from the link stickied at the top of the forum for detailed info on timing belt installation
Old Jan 8, 2010 | 06:51 PM
tonyv57's Avatar
Thanks Bugs
Not a real mechanic, so just a little worried that I may have screwed things up. You make it sound fairly easy. thanks for the input
Tony
Old Jan 8, 2010 | 07:27 PM
raydouble's Avatar
FSM here.....
http://www.ncttora.com/fsm/1990-1995...5/contents.htm
The 3.0 is a non-interference engine btw...
Old Jan 8, 2010 | 07:39 PM
tonyv57's Avatar
Thanks for the "manual link" raydouble. What a great help! .......Tony
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
