Elocker added, now no rear sway bar......
Old Jan 10, 2010 | 07:20 PM
schmatt's Avatar
Well, I ended up putting in a Toyota Tacoma Elocker rear third in my 92 4runner.
All of that install went pretty well, but now it is clear that my stock rear sway bar does not fit due to the large lump on the side of the diff where the actuator sits.
Has anyone else run into this problem? I must keep that rear sway bar......especially after I add OME 900's.....
Any ideas?
Old Jan 10, 2010 | 07:38 PM
mastacox's Avatar
If you want the e-locker, you don't need the swaybar.
Heck, I took off my front and rear ones
Old Jan 11, 2010 | 05:26 PM
schmatt's Avatar
OK.....I don't think I could weld-fix it if I wanted to......
Thanks for the info
Old Jan 11, 2010 | 05:30 PM
camo31_10.50's Avatar
well ya could get your stock sway bar cut in half and designed around the locker.
just a thought
Old Jan 12, 2010 | 12:08 AM
Matt16's Avatar
That won't work, heating it will ruin the temper of the spring and it will bend. I think you're best bet would be to reconfigure a swaybar from a 1996+ 4Runner with an e-locker to work on your axle. You might have to weld on some new mounts, but it shouldn't take much work at all.
As for needing the rear swaybar, the rear coils on the 4Runner flex really well and removing the rear SB makes for a really tippy truck. I flopped my truck when i had the rear SB off.
coffey50
Jul 28, 2015 10:55 AM
Logz808
Jul 26, 2015 07:09 AM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
Vargntucson
Jul 4, 2015 12:15 PM
