update on 86 rebuild.
Old Sep 21, 2006 | 06:52 PM
tampabayota's Avatar
ok yota techers i need some help. i just pulled the oil pan off the motor and found some plastic shards and a piece of metal. so i think the piece of metal is part of the timing chain cover, and the plastic was the chain guides. i have a picture of where the piece of metal goes so you can see its the first pic.
i also have another question there is this part that bolted to the side of the head and it went to the intake and had some hoses coming from it. well after taking it apart it looks like its plugged, what is this part and what does it do. i also have some pics of it they are the last three pics.
Old Sep 21, 2006 | 07:01 PM
Elton's Avatar
you have the first part right and the 2nd part cant help you there some one will chime in
Old Sep 21, 2006 | 07:20 PM
toyaholic's Avatar
holy cow. that's your egr.
Old Sep 22, 2006 | 03:12 AM
is the timing cover ok to use like this, and yes the ports on the egr are plugged with caps. Did someone do this to get around the smog stuff ?Any help please:pat:
Old Sep 22, 2006 | 04:42 AM
trythis's Avatar
I would replace that EGR, pricey, but the computer uses the EGR system to regulate RPM, fuel volume, and auto tranny shifting, maybe more. (mainly emissions, and if you can think at all, that is the most valuable) The whole EGR system on mine was a little messed up here and there, but eventually, I got it running well. Replacing my EGR valve and fixing teh EGR system made my truck run a lot smoother, and fuel efficiency went up from 14 mpg to 18. It is up to 20+ now, but after other attention.
Old Sep 22, 2006 | 06:34 PM
i dont plan to run smog stuff or a cat is that ok
Old Sep 23, 2006 | 05:50 AM
Tim_Snapple76's Avatar
Running without a cat will cut your gas mileage to pieces. I'd replace the egr system, budget permitting. Tim
dzldust
7
Oct 6, 2015 05:39 AM
voiddweller
Sep 28, 2015 11:21 PM
sonorn67
Sep 19, 2015 05:39 PM
Kytowboater
Sep 17, 2015 11:17 AM
