High speed braking vibration
Old Sep 11, 2006 | 10:38 AM
grubby81's Avatar
Have a 94 4x4 ext. cab. I remember reading a thread earlier this year about someone who had a similar problem regarding some vibration when braking at speeds above 50mph. Can't find the thread anymore. Anyone have any ideas what may be causing this? Thanks.
Old Sep 11, 2006 | 10:47 AM
cweich's Avatar
you might try turning you rotors, sometimes they warp and will chatter when you are braking.
Old Sep 11, 2006 | 11:05 AM
4Runner 4Play's Avatar
Ditto for the rotors... I had that problem a while back. Got them re-turned and it went away!
Cheers, Lee
Old Sep 11, 2006 | 11:13 AM
kmcc78240's Avatar
must likely the rotors, like they said. Mine went away after changing the rotors as well.
quick Hi jack -- When I brake now i pulls to the right, only when braking, is this a rebuild the caliper type thing or air in the break line and bleed the brakes?
sorry about the highjack, turn your rotors or replace them.
Old Sep 11, 2006 | 11:19 AM
Yota82's Avatar
Could be 2 things 1. Rotors 2. Tire balance issue.
kmcc78240,
Most likely a caliper, check the brake lines and make sure one is not pinched though.
Old Sep 11, 2006 | 11:35 AM
curtiswyant's Avatar
Might wanna check your wheel bearings while you're at it!
Old Sep 11, 2006 | 11:38 AM
grubby81's Avatar
Thanks.
Guess I should have mention that rotors had been turned. Dealer performed work as well as wheel bearing repack.
Old Sep 11, 2006 | 11:44 AM
kmcc78240's Avatar
Originally Posted by Yota82
kmcc78240,
Thanks I forgot about that. I recentlty repacked the bearings when I did the CV joints
Old Sep 11, 2006 | 01:27 PM
leebee's Avatar
you might also want to check the lugs, over torqued lugs can cause the rotors to warp and lead to braking vibration.
lee
jasonty
41
Dec 23, 2018 01:00 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Johntom240
7
Jul 13, 2015 12:18 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
