92 22re tmiming issues
Old Sep 21, 2006 | 08:35 AM
toyotamanxxx's Avatar
i have a 92 4 runner...with 22-re...
with my distributor turned all the way clock wise ,im about 8-10 deg. BTDC....
.i spun the dist. one tooth and that put me right on TDC...but now the distributor is all the way counter clock wise now....that is just backwards from the start point......
i cant seem to get this right... also from front to back what are the cylinder #'s..?..... 3-2-4-1...?????? thanks for your help
Old Sep 21, 2006 | 04:45 PM
MMA_Alex's Avatar
do a search i know this has been asked before...i wanna say other people with the same issue had the timing chain off a tooth? but a search will definately yield results
Old Sep 21, 2006 | 04:52 PM
miket223's Avatar
If the engine runs good then your timing chain is probably setup correctly. I would make sure your TPS is adjusted properly. An improperly adjusted TPS will never allow you to set the timing correctly. A common issue is a TPS that doesn't think you're idling and so it signals this to the ECU and it advances the ignition timing.
Old Sep 21, 2006 | 05:04 PM
Saint_Berzerker's Avatar
Yep, I vote TPS also.
Old Sep 21, 2006 | 05:07 PM
Elton's Avatar
good god the font sucks i feel like i just got yeld at and good thing it wasint in caps
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
