High mileage valve adjustment
Old Sep 10, 2006 | 06:53 PM
coooray's Avatar
ive been trying to adjust some of the valve noise out of my 22re. its got 150K miles on it. should i still be trying to set the valve lash at 8 and 12 thousandths or something else. i have adjusted twice now and it still sounds like at least one of the valves is ticking (more like knocking) loudly. is it possible something else is going on in there? bad rocker arm or something??
Old Sep 10, 2006 | 07:54 PM
Saint_Berzerker's Avatar
Heck, my "new" engine only has about 10K or less on it and it ticks/knocks like crazy...I can't get rid of it. These are noisy little engines....tons of posts on this site about it...lol.
You can adjust your valves until hell freezes over and usually can't get rid of the tick. I'm not saying that isn't your problem..just mentioning that. I doubt it's your rocker or anything, but I don't know.
Old Sep 10, 2006 | 08:08 PM
coooray's Avatar
yeah i know its a noisy engine by nature, but this doesnt sound healthy at all...
Old Sep 11, 2006 | 03:33 AM
MMA_Alex's Avatar
make sure you're doing em hot. I had the same issue, and so did a ton of other people. I ended going .011, .007 hot, and that seemed to be much quieter. Either way they tend to be noisy untill the engine is warm.
Old Sep 11, 2006 | 03:41 AM
kyle_22r's Avatar
are you sure that it's not the timing chain?
Old Sep 11, 2006 | 06:40 AM
MMA_Alex's Avatar
excellent point. when you remove the valve cover to do the adjustment take a look at the timing chain and guides, and see if theyre in good shape.
Old Sep 11, 2006 | 07:31 AM
Buck01's Avatar
I started runnning thicker oil..it seems to quite them down a little.
Old Sep 11, 2006 | 09:14 AM
stock87's Avatar
The valve adjuster stud tips wear down and are no longer slightly convex, so you get the noise because the surface riding across the valves is uneven. Last I checked, new ones were about 2 bucks apiece from http://www.1sttoyotaparts.com/ PN# 90913-05019
They are noisy engines, but even at 8&12, you can really only hear the valves at idle on my truck.
Old Sep 11, 2006 | 04:53 PM
coooray's Avatar
the timing chain isnt going to make a rythmic tick/knock though right??
guess ill replace the adjusters and re-adjust the clearances. ive been doing them with the engine hot too...
montanatruck
Feb 26, 2017 07:07 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
razorman8669
Jul 12, 2015 12:13 PM
