What to take the power from?
Old Sep 16, 2006 | 06:07 PM
linuxrunner's Avatar
ok i got an aux fuse block and i have everything ready, except that i don't know where to tap into for the power? I want the whole block to be on when keys are in acc/on position and off when truck is off. Where do i go to get enough power and not make problems?
Thanks
Old Sep 16, 2006 | 07:19 PM
Bump, I would like to finnish this tonight if i could
Old Sep 16, 2006 | 07:38 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
my first response was to get it straight from the battery (with an in-line fuse of course) but then you said you want it on only when in the on/acc position. i have wondered this myself. i know how to do it with a relay but im not sure if any relay can handle that voltage and wattage straight from the battery.
Old Sep 16, 2006 | 09:24 PM
mastacox's Avatar
Thanks
Either the block should have a relay, or you'll need to add one (The Painless "Cirkit Boss" blocks have built-in relays, but if yours doesn't they are easily added). Remember, the relay will have to be rated for the total power of the block, depending on what accessories you will want to add. Also, pay close attention to the size wires being used and how much power is going through them, we don't want any electrical fires after all.
The relay will have four plugs on it (two circuits). One will be the "high power" circuit. For this one you will plug one side into the positive power on the battery, the other end to the power for the fuse block. The other will be the "low power" circuit that turns the "high power" circuit on. For this one, you will probably want to tap into the cigarette lighter power wire for the hot side, and ground the other side. This way, when the ign is on (and therefore cigarette lighter is on) your fuse block will turn on too. Alternatively, you can tap int ECU power, but the cig lighter is easier to get to.
That ought to do it
Old Sep 16, 2006 | 09:29 PM
That ought to do it
Perfect, thanks i'll pick up a relay tomorrow. I figured a relay would be the best way to do this. I might use the cig lighter or ECU as the fuse block is in the right kick pannel with the ecu. Thanks much. I'll see if i can snap a few pics when i am done.
Old Sep 17, 2006 | 03:09 AM
ovrrdrive's Avatar
You'll definitely need to use a relay like the others suggested...
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
