Rear Diff seal part # question
Old Sep 15, 2006 | 10:48 AM
brandontrek's Avatar
Does anyone know the part number for the rear diff seal that is between the rear gear housing and the input driveshaft(looks like a bellhousing....) housing?
Also does anybody have any pointers on replacing this seal? i am going to be replacing the pinion seal at the same time.
I have a gear oil leak around the rear diff. I just cleaned out the breather, but it looks like my seals are already compromised, so i might as well replace them(i have some extra time this weekend....and feel like wrenching a bit....)
Thanks
Old Sep 17, 2006 | 06:09 AM
leebee's Avatar
are you talking about the axle seals, inner and outer? if so, #90310-50001 & # 90313-48001. if your seals are shot, youll probably require new wheel bearings as well, # 90363-40020-77. youll need access to a press to get the brgs off and on the axle shafts. i cant locate the pn for the pinion seal but its pretty straight forward and not expensive.
you might want to check through this: http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf .
lee
GreenLion
Jun 7, 2021 10:49 AM
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
merc1100sc
Jun 26, 2015 05:24 PM
