front brake problems.
Old Sep 16, 2006 | 07:06 PM
fatdaddy's Avatar
i have a 88 4runner that will not release the front calipers. i have changed the calipers, shoes, rotors and master cylinder on both sides and the front brake still will get hot and not release. any thoughts? Booster? what about the proportion valve can it go bad?
Old Sep 16, 2006 | 10:25 PM
jeepboyny's Avatar
Replace your brake hoses and check for crushed metal lines
Old Sep 16, 2006 | 11:11 PM
SoiledGreen98's Avatar
Ditto
Old Sep 17, 2006 | 05:39 AM
psychobillyman's Avatar
The proportion valve could also be dirty.
Old Sep 17, 2006 | 06:52 AM
fatdaddy's Avatar
thanks for the replys. there are no crushed lines visible. if I drive the runner and don't use the brakes to stop (use the trans and the e brake to stop) evrything is fine but once iI use the brakes they start dragging and heat up. once this happens i have to let them cool and they release.
Old Sep 17, 2006 | 06:58 AM
CyMoN's Avatar
did you flush your lines when you changed your calipers
also make sure you dont have a collapsed rubber line
you may need shims for the pads
Old Sep 20, 2006 | 06:03 PM
fatdaddy's Avatar
thanks for all the help. I finally traced the problem to my new master cylinder and replaced it and fixed the problem.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Sep 4, 2015 09:27 AM
terminator
Jul 27, 2015 07:13 PM
