Locking hub help Asap
Old May 10, 2008 | 05:24 AM
dcmbsc's Avatar
I just re did my front axle on the right side and got the truck back on the road, the hubs are staying locked on bothsides and are spinning and the hub will only turn half way, way to fix please?
Old May 10, 2008 | 05:27 AM
camo31_10.50's Avatar
hmm...when i started to reply i was going to say you packed too much grease therefore it cant engage...but..they are staying engaged...sorry cant help ya there
Old May 10, 2008 | 05:35 AM
mt_goat's Avatar
Aisin hubs I guess, this should help.
https://www.yotatech.com/forums/f116...volved-127956/
Old May 10, 2008 | 05:39 AM
xcmountain80's Avatar
Pull em apart and put em back together again and again. You might need to install them in the locked position to get them to work properly.
Aaron
Old May 10, 2008 | 06:11 AM
dcmbsc's Avatar
Once i have got the hubs turned from lock to free , what is a method I can use to check that the truck had free hubs working?
Old May 10, 2008 | 06:16 AM
1stgen4gunner's Avatar
the sound should be a dead giveaway, if the engine sounds quieter and doesent roar, also the truck should pick up speed faster.
Old May 10, 2008 | 06:33 AM
mt_goat's Avatar
Easy way: while in 2WD reach down and see if the CVs will spin.
G-off
Dec 29, 2015 12:44 PM
Jason4X4
Sep 17, 2015 08:02 AM
skouba
Sep 14, 2015 06:58 AM
zz_denis
Sep 6, 2015 03:43 PM
AkitaDog
Sep 3, 2015 09:01 PM
