Starting issue (ignition??)
Old May 9, 2008 | 07:06 AM
devinwwu's Avatar
Ok so i have a new problem for you guys. I'm hoping its one that has already been diagnosed for someone else, but my searching revealed nothing.
On my 1990 3vze powered std pickup, i have a starting issue. It seems to only happen when i haven't driven the truck in a day or so. When i go to start it, i crank the key and i'll get a click... the first couple times it happened, i turned the key off, swore and eventually replaced the starter contacts (which were worn, but not that bad) I put it all back together and the same thing happened...
Tried it a few more times a few different ways and finally for some reason i held the key in the "crank" position. i got the first click as always, then a few seconds later another, then another until after about 15-20 seconds it started up...
Any ideas?
Old May 9, 2008 | 04:29 PM
leebee's Avatar
check out www.4crawler.com for tips on repairing the ignition switch. check all your ground connections as well, could be that simple.
lee
Old May 9, 2008 | 05:15 PM
abecedarian's Avatar
Loose grounds. Bad ignition switch.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
