oil leak
Old Apr 30, 2008 | 04:13 PM
NoLimitCustoms's Avatar
oil leak
I just replaced the water pump on my 22re.... before i did this, it had a small oil leak(they all do). Now, the oil is pouring out of the front of the motor... did I do something wrong?
Old Apr 30, 2008 | 04:17 PM
LTrunner's Avatar
did you remove the timeing chain cover with the water pump?
Old Apr 30, 2008 | 04:18 PM
Nope, all I did was remove the old water pump, and put a new one on...
Old Apr 30, 2008 | 04:20 PM
LTrunner's Avatar
hummm...sounds odd can you pin-point where it is leaking from
Old Apr 30, 2008 | 04:24 PM
no, If i could pin-point it, I wouldnt have a problem.... it seems like its just everywhere in front. the new water pump is covered in oil, so im guessin its comin from the top somewhere...
Old Apr 30, 2008 | 04:27 PM
LTrunner's Avatar
there's only a fwe places it could be leaking form in the front...from top to bottom...the vavle cover gasket....the HG( the part between the head and the timeing chain cover...and the front main seal(crank shaft seal)...that's al i can think for oil to leak from in the front of the enige
Old Apr 30, 2008 | 04:29 PM
my guess is that its coming from the head and timing chain cover.... how would I fix that?
Old Apr 30, 2008 | 04:41 PM
LTrunner's Avatar
the cheap way that won't last long, rtv the snot out of it...the right way to fix it replace the HG...
Old May 1, 2008 | 08:18 PM
toyota_mdt_tech's Avatar
Replace the front crank seal along with the oil pump o-ring.
Old May 1, 2008 | 08:28 PM
abecedarian's Avatar
And make sure water isn't getting into the crankcase.
Old May 1, 2008 | 08:31 PM
iamsuperbleeder's Avatar
good point, especially if it got worse after the H2O pump change!
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
