Trans and engine stuck
Old Jul 5, 2008 | 12:43 PM
HardCharger81's Avatar
I bought a class 7 desert racer project that has a 22ret and the heavy duty R151 (?) trans. We pulled the motor today because I'm going to go though it and convert it back to non turbo.
Anyway, my problem is this, we can't get the engine and trans seperated.
Its past the dowels in the motor, but now it just seems stuck.
Is there something I'm missing? This isn't my first overhaul, but it is my first Toyota, so thanks in advance.
Old Jul 5, 2008 | 03:56 PM
InternetRoadkill's Avatar
I'm guessing the pilot bearing is frozen to the input shaft.
Old Jul 5, 2008 | 04:00 PM
Flash319's Avatar
x2
If the dowels are out there is nothing else.
Old Jul 5, 2008 | 04:10 PM
bigt's Avatar
yeah might need to break out the towstrap lol
Old Jul 5, 2008 | 06:05 PM
Alex 400's Avatar
I think you nailed it. getting even pressure on the bell housing to pull it apart would be really nice. maybe some of those clamps that can be used for prying apart aswell as clamping? (mini high-lift jacks?)
Old Jul 5, 2008 | 06:27 PM
I've had that happen to me on an old Volvo station wagon (worst car I ever owned). The pilot bearing failed and welded itself to the input shaft. The bearing then spun and fused to the crank. I spent the better part of a day trying to get the tranny off the back of the engine.
Old Jul 5, 2008 | 06:38 PM
Alex 400's Avatar
how did you get it apart?
Old Jul 5, 2008 | 06:51 PM
Lots of colorful language, wooden blocks, a pry bar, and brute force.
Actually, if was smarter then, I should have tied a hand winch to the output flange and the rear axle and just winched the bugger out. Those 2-ton hand winches are really handy.
Old Jul 5, 2008 | 06:55 PM
Alex 400's Avatar
Yeah I was actually thinking of the pry bar thing first, I just wanted to think of a better way to do it before resorting to that idea. hahahhahaha
The winch idea could work too, the only thing is that he already has the trans and motor pulled, so he would have to secure the motor some how to reef on it.
Old Jul 5, 2008 | 07:01 PM
Put a chain on the motors mounts and chain the block to something. Then chain to a tree or heavy vehicle with the winch. Just make sure everything is pulling in a straight line.
Old Jul 5, 2008 | 07:06 PM
Alex 400's Avatar
well if it was my truck, I would be doing it this way. tie it to the diesel truck, 4wheel low, first gear and let the clutch out. (that could go very badly) DON'T DO THAT !!!!! the come-a-long or hand winch would work fine. Good luck
Old Jul 6, 2008 | 08:15 AM
Thanks for your help guys, I might take it to work and give pulling them apart a try there.
Old Jul 6, 2008 | 12:55 PM
Alex 400's Avatar
good luck!
Old Jul 6, 2008 | 01:18 PM
bigt's Avatar
heat some THRUST ..NOT P.B BLAST not WD40 GET THRUST!!!! some pry bars BFH maybe a come along or winch... show that motor and tranny who does the
gosh darn driving!
Old Jul 7, 2008 | 06:26 PM
Well, this thing was seized! We chained the engine and trans to 2 opposing forklifts and pulled. And after some scary noises, and some damage to the clutch, they came apart. Everything else seems good.
Old Jul 7, 2008 | 06:41 PM
Alex 400's Avatar
Hey that was kinda like my idea! hahaha. I am glad it came apart for you.
kazuya2416
Apr 5, 2024 02:17 AM
Eggslinger
Jun 8, 2019 03:32 PM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
