22re- shaving head 20 thou. for compression
Old Jul 8, 2008 | 09:35 PM
84 yota ex-cab's Avatar
I was wondering how much compression shaving 20 thou. off a 22re head would give you. I was looking at pistons but they are really expensive.
Old Jul 9, 2008 | 08:28 AM
Flash319's Avatar
Why? Do you want to run premium gas for some reason? You will get a higher compression but will do very little for power.
Old Jul 9, 2008 | 10:36 AM
dcg9381's Avatar
You should adjust you cam timing back into spec if you cut that much out of the head.. so factor that cost in also.
Old Jul 9, 2008 | 10:58 AM
fast68's Avatar
and mess up the timing chain
woops beat me to it
plus then you would have to shave the timing cover down
andthen anything bolted between the head/intake and block would need shortened
and so on and so forth
Old Jul 9, 2008 | 11:04 AM
Matt16's Avatar
I think you'd need premium gas or better frankly.
Old Jul 9, 2008 | 02:50 PM
abecedarian's Avatar
.020 off would probably not do anything to the engine if you didn't get the cam timing back into spec since the cam would be lagging. once you get the adjustable cam gear and dial it it, then you might be seeing some issues.
Old Jul 9, 2008 | 03:01 PM
Sked's Avatar
I'm @ 10.2:1 on my 20r and it made big difference IMO. Yes i have to run 91oct min and sometimes 94 when im playing around with timing but my truck aint slow anymore even on hills. Before keeping my truck at 100km/h on the highway was hard and impossible if there was hills, but now i can max out my speedo in 4th with no troubles.
But at the sametime i did the pistons I totally reworked the head with big valves/cam.
Old Jul 10, 2008 | 11:45 PM
Matt16's Avatar
Did that kill your fuel economy? What are you getting now?
Old Jul 11, 2008 | 02:53 AM
Sked's Avatar
i get 20-22mpg around town with 31's and 4.37's and i really like to rev my engine. If i babied it i might get up to 25 if i tried very hard, but this head revs to like 6k with a dip of the throttle.
Old Aug 6, 2008 | 06:08 PM
Targetnut's Avatar
I worked these numbers when I did my head, but I'm not sure where my notes are.
If I recall correctly, you cut almost 2cc's from the combustion chamber volume per .010" shaved from the head. After unshrouding my valves, and smoothing out the combustion chamber I was up to almost 60cc's. I had .053" milled to bring the volume to about 51cc's which gets about 10.2:1 or so compression ratio. at this compression ratio I run high test.
If you took off .020" with a stock volume of 56cc's that should get you real close to 10:1
I don't think .020" would have that big of an effect on cam timing, at least no more than a worn chain. But an adjustable cam gear would allow you to get that back.
I'll look for my notes and if I find anything different than what I've posted I'll get back with you.
the1998sr5
15
Jul 14, 2020 08:35 PM
84'22r
Feb 13, 2019 05:35 AM
old87yota
Oct 25, 2015 02:15 PM
o2raybid
Sep 4, 2015 12:45 PM
Jason Webber
Sep 2, 2015 03:30 AM
