Do I need new fuel injectors?
Old 07-08-2008, 02:23 PM
ThomasTedder's Avatar
I'm having my engine rebuilt, and am just wondering if I should have a new fuel injector(s) installed.
Does an 86 4runner have more than one?
Can the shop easily clean it while it's out?
Should I just replace it/them?
Old 07-08-2008, 02:25 PM
fillsrunner4's Avatar
I would say not to just cause they are expensive and easy to fix down the road if you have to. You could however put new O-rings on and if you really want have a shop equalize them for you that would be a bit cheaper than all new ones. And yes you have 4 injectors for the 4cyl and 6 for the V6
Old 07-08-2008, 02:44 PM
abecedarian's Avatar
It wouldn't hurt anything to have the shop send the injectors out to get cleaned and flow matched. The place doing the cleaning will let you know if any are not serviceable and need replaced. But it is not cheap. You can ask your mechanic about it.
The 22RE has 4 fuel injectors and they are very easily removed when the intake is off the engine, and may even be removed already.
Old 07-08-2008, 02:59 PM
tulsa_97SR5's Avatar
lots of folks here have reported great results having witchhunter cleaning their injectors, https://www.yotatech.com/forums/f39/...service-92823/
Old 07-08-2008, 04:43 PM
I think that's too far for the turnaround I need. I'll look into having the cleaned.
Blamalam
03-12-2022 07:34 AM
RatOmeter
10-22-2015 03:17 PM
Tacoma1313
08-17-2015 05:44 PM
pyramid
07-30-2015 10:05 AM
HookahRoo
07-20-2015 07:06 PM
Quick Reply: Do I need new fuel injectors?
