spare tire question!
Old Jul 8, 2008 | 05:46 PM
904_runner's Avatar
Okay, my buddy has a 33x13.50 micky thompson baja claw, brand new, never touched ground, that he said he would give me for $40. I am just going to run this as a spare. Would this work on a stock sr5 wheel? I think it might be too wide but for a spare that won't see the ground often, and if any for a very short time. whats you opinion? Please help, if im going to pick this up it would be tonight!
Old Jul 8, 2008 | 05:52 PM
904_runner's Avatar
Is this worth purchasing? Im running 33x12.50's on it now, and these baja claws don't look any wider than the 12.50's
bigt's Avatar
how big r your normal tires??
they might rub if your dont have any lift! its wide
yeah it would be worth it as a spare why not!
thats a 100+ dollar tire if you get a rim too def get it!
Old Jul 8, 2008 | 05:55 PM
904_runner's Avatar
Actually i see them for $206 for 33x12.50's. Can't find any 13.50's though online.
I have a 4" lift, 12.50's don't rub. I think the stock rim im asking if it would fit on is a 15x7
TOYOTA 1's Avatar
its pretty wide for a 7" wheel.. i think it would mount.. for 40 bucks id say go for it!
Old Jul 8, 2008 | 05:59 PM
904_runner's Avatar
Shoot, i was thinking it was too wide also, but i was curious since it is a spare. and $40 for a full size spare.
Basically i really want to know if it will mount, and if it would be okay as a SPARE which i hope will never see ground, and if it does it would probably be for like 25 miles tops, which is about how far away i go wheeling.
Old Jul 8, 2008 | 06:02 PM
TOYOTA 1's Avatar
if it will mount, which i think it will. then it would be a great spare..
Old Jul 8, 2008 | 06:17 PM
904_runner's Avatar
Okay, cool! Thanks for the reply!!!!!
And if anybody else wants to add, like if they tried this and it worked or if it failed, i would like to hear!!!
Thanks!!
Old Jul 8, 2008 | 06:19 PM
algranger's Avatar
do it! if nothing else you can resell for more
Old Jul 8, 2008 | 06:21 PM
corax's Avatar
at least with that skinny rim you shouldn't have to worry about popping a bead running low psi
Old Jul 8, 2008 | 06:24 PM
904_runner's Avatar
Okay! Good points!
Or buy another rim for $40
Thanks!
Old Jul 9, 2008 | 03:57 AM
WFO's Avatar
WFO
Im runing a 15.50 on a stock Toyota wheel for a spare. Granted its a 38 but they fit on the wheel fine. I would just be worried about clearing balljoints and the frame.
Worth a shot though.
Old Jul 9, 2008 | 05:57 AM
94Runner4x4's Avatar
yea it should work, the onyl reason it's better to get a wider rim with wider tires is for offroad and daily driving but for a spare it should be fine, and yea make sure it fits up front without rubbing the UCA cause if you don't fix that before you need to use it, it won't be any use up front at least
Old Jul 9, 2008 | 07:03 AM
904_runner's Avatar
Okay, well i ended up picking up the tire. Freaking beefy!!
Anywho, i plan on taking it to a tire shop if any are up here due to this fire, and get it mounted.
If it doesn't clear on the front, then i guess i will be doing a couple of switches on the truck in order to run it in the back.
Now question is, when i buy new tires, if i were to run the spare in the back and say its taller than the tires i have when i get new ones, since i have a locker in the back, how would i go about using it? Could i air the taller one down so they are ruffly the same hight and get away with it?
Old Jul 9, 2008 | 07:37 AM
Crawdad's Avatar
It'll mount fine, but it will pooch a lot, and reduce overall diameter.
Old Jul 9, 2008 | 07:41 AM
904_runner's Avatar
Okay, i can deal with that, at least i have a full size spare now.
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
