Is this thing supposed to move?
Old Mar 13, 2021 | 06:06 PM
DrCreosote's Avatar
Hey y'all. I've been chasing down a noise, kind of a rattle/knock that sounds like it's coming from the front of the engine, but not from inside the engine. The engine was rebuilt a few years ago, but was a short block deal, so I was cheap and kept a lot of parts that I have been replacing one at a time. Thinking my noise was the water pump, because I narrowed it down, I tore into it and removed a perfectly serviceable water pump, but while I was cleaning the gasket off the block, I noticed that the timing pulley moves quite a bit, probably an inch in each direction. My sense is that this thing should be basically locked to the crankshaft. Is there supposed to be any play in this thing at all, or should it be a tight, non-moving fit? Incidentally, it makes the same noise I've been chasing down and that's something.
1990 4runner 3vze automatic 4x4
Here's a handy diagram showing the part I'm talking about. If necessary, I can go out tomorrow and take a video of the play it has and the noise it makes.
ThanX
Last edited by DrCreosote; Mar 13, 2021 at 06:06 PM. Reason: forgot to attach image
Old Mar 13, 2021 | 06:28 PM
millball's Avatar
Looks like you have circled the crank pulley that drives the timing belt.
It should be rigidly keyed to the crank snout with no apparent slop.
Old Mar 13, 2021 | 09:03 PM
QuiGonJon's Avatar
No the timing pulley should be on tight with no movement. It's actually a huge pain to remove most of the time because it doesn't budge
Old Mar 14, 2021 | 12:46 AM
DrCreosote's Avatar
Cool beans, thanX.
I kind of found that it was loose by accident. Been away from working on cars too long and forgot all the important things. I guess with it being loose, it should come off easy.
Old Mar 14, 2021 | 08:56 AM
millball's Avatar
Please show us some pics of it dismantled. Sure hope you don't find the crankshaft keyway damaged.
Old Mar 30, 2021 | 04:49 PM
millball's Avatar
Any advance on this repair???
DrCreosote
May 19, 2020 06:51 PM
rbh261
14
Jun 11, 2011 08:35 AM
hayduke
May 5, 2010 03:39 PM
lovemyrunner
Apr 20, 2009 05:19 PM
george16
Jun 12, 2003 01:59 PM
