transmission/transfer case fluid mixing
Old Jan 24, 2021 | 05:43 PM
19874skinner's Avatar
So i have a new to me 4runner with a chevy 4.3 - 700r4 - advance adapters 50-5705 - dual marlin gear driven tcases, motor and trans are from 1992 and tcases are from 1987. I overheated the transmission and blew a few seals, had an atf leak at the bellhousing that went away when it cooled down (could be vent breather). a few days later, i drove about 60km highway and upon arrival i noticed an oil leak coming from the cases, somewhere near the top but im not 100% on that yet. I pulled the fill plug on the rear case, expecting to be low on fluid and found it be overfull by quite a bit. drained it to the appropriate level, checked the trans fluid and it was a bit low so filled it, then drove it back home and found the rear case to be full of fluid again.
my questions are:
-were gear driven tcases like the one i would have in my dual cases offered in a stock toyota automatic transmission?
-does a gear driven tcase like the one i have in my duals have a seal on the input shaft in front of the bearing to stop fluid going between transmission and tcase? depending on the answer to the first question, would it share the fluid between the manual trans and the tcase? if they were available in automatic transmissions, would it rely on a seal on the trans output shaft, the tcase input shaft, or both?
-it looks like there is an oil seal in the adapter itself between the transmission and first case. could this be the only seal that keeps the atf and gear oil from mixing together?
Old Sep 21, 2021 | 09:46 AM
muddyboy's Avatar
Red face leak between t-case and trans
19874Skinner-
I am looking for an answer to a similar problem with my 1987 SR5 pickup.. ie---my transfer case loses lube that appears in the transmission. It has occurred several times. My research shows there is a seal on the trans output shaft ( manual. W 56 trans. Don't know about the automatic trans. ), and none on the t-case input. Only on the front and rear output shafts. If lube wasn't $18 bucks a quart it wouldn't matter to me, but I'm thinking I might try to get the t-case off and renew that trans seal.
I hope this might be some use to you.
I'm 80 years old and don't know much about the ways of the internet, so I hope I didn't mess up with my reply.
19874skinner
Domestic Swaps
Jan 24, 2021 05:40 PM
pplusent
May 30, 2019 09:21 PM
yourrealdad
Jul 29, 2015 11:08 AM
jdrum1
Sep 29, 2013 08:00 PM
stomper4x4
Mar 20, 2010 02:20 AM
