Lost key/pulled ignition lock cylinder/broken ignition?
Old Apr 1, 2021 | 06:39 PM
gpup's Avatar
Hey guys. First time posting here, y’all have helped me out with a lot of yota stuff, and basically taught me how to mechanic.
So I’m trying to sell the first gen, lost my key, pulled the ignition lock cylinder, and now I’ve got a free floating ignition and locked steering wheel. Can’t get it to turn over or electronics to switch on. Check it out
Thanks fellas and ladies
Old Apr 2, 2021 | 06:31 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I'd replace the ignition switch(not the lock) and go from there.
Old Apr 2, 2021 | 03:49 PM
swampedout's Avatar
5 Year Member
If im reading right, you removed the lock cylinder? Cant you just replace that? You can buy one almost anywhere.
Old Apr 2, 2021 | 03:55 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Curious, without the key how did you pull the lock? Punch the pin? The key code is on the passenger door lock. Should be a “K” followed by four numbers. That would get the cylinder working. But the lack of a spring return in the electrical ignition switch, and the fact that turning it with a screwdriver doesn’t start the vehicle, makes me condemn that part.
EvergreenHilux
Mar 21, 2024 02:14 PM
sinner
Mar 18, 2014 12:39 PM
O'right
Oct 1, 2010 01:05 PM
ramblin86
Jan 18, 2009 06:47 AM
hafftrak
Jul 29, 2005 11:35 AM
