Strange Clicking sound
Old May 25, 2009 | 04:42 PM
87Yota22r's Avatar
A few months ago a strange clicking sound developed on my 22r. Seems to be coming from the front of the engine and sounds like it's external to the engine block. Wondering if anyone else here has experienced a similar problem.
The sound increases with RPM but is not always there. Seems to be independent of temperature, whether the engine is hot or cold etc. Some days it's really bad and others it's non existent. It's not the natorious valve lifter click and it doesn't sound like a rattling timing chain. Also, when the clicking problem is there, it goes away at certain rpms and gets louder at others.
Thinking it was the water pump, I replaced it today but the clicking is still there. Any ideas? Thanks a ton for any help! I could post a recording if it helps.
Old May 25, 2009 | 06:38 PM
toyota4x4907's Avatar
you say you "THINK" its not the TC...but have you taken the time to look?
Old May 25, 2009 | 08:24 PM
87Yota22r's Avatar
ya, I pulled the valve cover and peaked down inside. Guides are still intact and chain seems to have good tension. Chain was replaced approx 30K miles ago. The sound does not sound like its inside the block, it doesn't sound like a knocking or rattling. The chain used to rap a bit on start up, which is why I had it replaced. The current sound is not similar to that. Very sharp, almost wet clicking sound, if that makes any sense.
Old May 25, 2009 | 08:31 PM
1dirtyota's Avatar
I ha d broke a bolt on the bottom of the tc cover on mine. It coused the cover to vibrate and the chain rubbed the cover as it rapped under the crank.
Old May 26, 2009 | 11:20 AM
87Yota22r's Avatar
Thanks for the input guys. The sound changed a little after I replaced the water pump so now I'm thinking either the idler pulley, the belt or the alternator. Anyone ever heard of a clicking belt?
Old May 26, 2009 | 01:49 PM
1dirtyota's Avatar
maybe bearning in alternator, power steering pump, or air compressor going bad
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
zeflower
Aug 30, 2015 06:52 AM
bvleonov
Aug 22, 2015 11:39 PM
cars-guy
Jul 11, 2015 07:51 PM
