86 4Runner, need some help.
Old May 30, 2009 | 09:23 PM
Ratoes007's Avatar
22re 1986 4runner. codes 6 & 12. Igniter checks out #53. & 7volts with 1.5v battery check. VAF is new. TPS new and adjusted. Fuel pump & Regulator new. Cold start inj. time switch new. Air Valve new. Head gasket new. Signal Generator new. Valves need to be re adjusted I had only set a cold lash and will need to adjust but they are ok, I hear 2 out of place. Timing is Spec.
Won't start cold. I have ohm'd out every possible thing with my dvom, and I can't figure out what is causing codes 6 & 12.
Injectors are ok, I ran the Toyota EFI cleaner with a half tank of gas & they sound the same with Stethescope up to ear & ohm out fine @ 2.5ohms. After head gasket was changed I drove for an hour and no codes, ran great. Now I am the same as before with no cold start, or increased idle when cold.
the ECU is out of an 87 4 runner and I have no Idea if its compatible or not? I just bought this and I do not know history of it except the fact that who ever owned it knew nothing and it took me a week to straighten out a lot of it.
Any Ideas thanks.
nanhodges2733
May 29, 2020 03:28 PM
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
88runnergomas
Jul 9, 2015 01:12 PM
bryan34w
Jul 6, 2015 05:53 PM
