Opinions: Are A340 Shift Solenoids A Service Item?
Old May 26, 2009 | 09:02 AM
OutlawMike's Avatar
Saw another post on the board about a sticking shift solenoid in an A340 auto trans.
I have an '89 3.0 auto with 134k miles on the trans.
As often as I see these posts, the thought has occured to me that the solenoids are almost a service item. Any thoughts on that? Also, what mileage would one target to swap them out? 150k?
When I get into a really remote area the one thing that nags at me is that thought of losing a shift solenoid in the middle of nowhere and having to deal with that on the way out.
Thanks,
Mike
Old May 26, 2009 | 10:15 AM
Shawn6string's Avatar
If you loose a shift solenoid, in most cases you can manually shift. one of mine went at abouut 225000 miles. Not sure when you should change them.
Old May 26, 2009 | 01:16 PM
4runnerx3's Avatar
If there is an electrical problem with the solenoids, you'll get a flashing code with the OD light. If there is a mechanical problem there will be no codes. There are no replaceable parts on the solenoids. You can pull them out and check them.
The shift solenoids work as a pair.
1st gear-no.1 on, no.2 off
2nd gear-no.1 on, no.2 on
3rd gear-no.1 off, no.2 on
OD- no.1 off, no.2 off
crammit442
7
Nov 29, 2017 12:30 PM
4x4-runner
Apr 18, 2017 09:08 PM
Gio8
Aug 27, 2015 12:14 PM
jgwerth
Jul 16, 2015 03:23 PM
mengquis
Jul 13, 2015 10:39 AM
