four wheel drive NO WORKY! help
Old May 24, 2009 | 10:25 PM
davidshocker's Avatar
so i was out playing around this past weekend and i got stuck in 2 wheel drive so i go and put it into 4H and the front tires were not spinning!!! my back tires were about 6in in the mud.
I just bought this truck, it was a REPO. so im not too sure whats all been done to it..
EVEN if i put it into 4L the front tires Do not SPIN!! not too sure what could cause this, can anyone help me??
94 4runner and auto locking hubs..
i'm going to buy some warn manual hubs soon, i called baxter auto parts and they want $190.00 but theey ask if i had A D D... WHAT IS A D D , LOL and if i did i would have to buy a nother kit for $100.00.
Old May 24, 2009 | 10:29 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
What year? Truck or 4Runner? Manual hubs? Where they in the locked position? More info is needed 'bout your rig, to successfully help you with your problems/troubles.....
Old May 24, 2009 | 11:09 PM
gary96360's Avatar
it could be a disconnected vacuum line. mine didnt work aafter the body lift cuz the line got ripped out. check on the front diff and see if you see some vacuum lines missing
Old May 24, 2009 | 11:16 PM
iamsuperbleeder's Avatar
oh boy, here we go
There's 3 types of hubs:
1) Manual (you have to get out and engage the locking hub at the wheel youself; the drive shaft and front axels are always locked together, but only spin when the transfer case is put into 4wd)
2) ADD, or Automatic Disconnect Differential (just as the name implies, this system disconnects one of the axels in 2wd, keeping the front drive shaft from spinning. the downfall to this system is the hubs, or lack-there-of. they consist of a drive flange at each front wheel, that permanently locks them to the axel shaft, so that the shaft is always in motion while driving, which usually leads to faster CV ware and tare)
3) Automatic Hubs (you can think of these hubs as having an almost ratcheting way of working. they ony engage when a force is sent through the axel shaft FORWARDS; these hubs will not engage in reverse, therefor Auto Hubs = no reverse 4wd... I know, stupid... but these at least do not keep the axels spining during everday driving)
But, as Freak said, we need to know EXACTLY what hubs you have to diagnos a little further
if you could, post a pic of what you've got; we can tell you really quick what you've got, and go from there
sounds like maybe you have ADD (the drive setup, not the disorder ) and a line has come undone, as Gary mentioned
Old May 24, 2009 | 11:22 PM
Sweet u guys are very good, u should write a book LOL..
Old May 24, 2009 | 11:27 PM
gary96360's Avatar
yep thats an add hub
Old May 24, 2009 | 11:38 PM
wyoming9's Avatar
Talking
If I read all the posts correct.
You got stuck at that point you engaged the transfercase to 4 H did you try and back out if you did the automatic hubs will not engage.
I don`t trust those things if you went forward one hub could have engaged and the other didn`t or neither one of them engaged either way one axle was spinning and not the tire .
Unless of course it is a problem in the front differential or transfer case.
I am curious just how did you extract your self.???
If you want to convert over to the manual hubs and don`t have the time to run around and get parts the hundred dollar kit is not a bad investment .
You only need the thrust washer s the nuts to hold the bearings and the locks and the new hubs of course.
Old May 24, 2009 | 11:46 PM
neilan's Avatar
If possible dont buy warn hubs. Im not quite sure if you can do the swap on a 94 but Id recomend getting some original toyota hubs and you will be much happier.
Old May 24, 2009 | 11:48 PM
i try to go forward but like i said both of the front tires would not spin! how did i get out, i had my friend with his 91 4runner pull me out..
and yes u can do the swap on a 94 for warn hubs, u just have to but a extra kit for the hubs for $102.
Old May 24, 2009 | 11:50 PM
gary96360's Avatar
\\he has add hubs not auto. and also just buy the aisin hubs from the autowrecker and just take it apart and regrease everything. and it will just bolt in.
Old May 25, 2009 | 12:22 AM
TNRabbit's Avatar
You're front diff is not engaging. It's probably the vacuum lines that actuate the Automatic Disconnecting Differential. Those of you telling him to get manual hubs, that will not help him!
yeppers, that's an ADD flange
actually eaiser to swap to Toyota/Asin hubs than you might think if you want to swap to manuals, I would DEFINATELY look into factory Toyota ones, not Warn's or whoever many reasons why; I'm not going to get into it
hit the seach button; there's TONS of threads about it
but you problem probably does lie in the differential disonnect, more so the the vaccum lines running to it
if you do the swap to original manual hubs, keep the drive flanges you remove; they come in handy for trail fixes if for whatever reason a hub gredandes on you
Old May 25, 2009 | 01:00 AM
thedude42's Avatar
check your vacum lines that would be my best bet
Old May 25, 2009 | 07:30 AM
Jay351's Avatar
x2
Old May 25, 2009 | 08:53 AM
It's either the vacuum lines, or 1 of the 3 VSV's themselves. They are on the passenger inner fender wall, close to the firewall.
Old May 26, 2009 | 05:47 PM
Skilo47's Avatar
i have a 91 toyota pickup and it is stuck in 4wd to
i have manuel hubs.
the 4wd light wont go off and when i unlock the hubs and put the t case into neutral and try to drive forward nothing happens the truck wont move.
Old May 26, 2009 | 06:11 PM
mattaway's Avatar
i have manuel hubs.
if it won't go in to 2hi, try backing up or pulling forward a few feet.
FYI- when you put the t-case in neutral, it won't spin the rear driveshaft.
Old May 26, 2009 | 07:42 PM
Skilo47's Avatar
stuck in 4wd
yes but my problem is it's stuck in 4wd im trying to get it to go back into 2wd .
is it possible the t-case is low on fluid? does it even take fluids? grease? oils? lol wtf is in that thing? XD
im sorry im no mechanic =(
anything you can recommend would be greatly appriciated though.
*edit*
also i tried driving back and forth a few feet but it didnt do anything.
and my lever wont go into 2hi it says it on the lever but the slot dosent seem to exist.
maybe the previous owner took it off for some reason and didnt put it back on right.
i usally just unlock the hubs and put the t-case into nuetral and the 4wd light would go off .
Old May 26, 2009 | 08:23 PM
91Toyota's Avatar
is the engine in neutral when trying to put it back into 2wd?
Old May 26, 2009 | 08:25 PM
space-junk's Avatar
i have manuel hubs.
hmm... so many things i could say...
