60/40 bench to buckets question
Old 05-22-2009, 10:11 AM
Hrddrvs's Avatar
I have a 1991 x-cab.I want to replace the 60/40 bench with bucket seats either out of a 4runner or truck.Will the bolt holes line up and do I have to add any holes?Also,I want to add the center console as well,can I use a 4runner or truck console?I appreciate any help.Thanks.
Chris
Old 05-22-2009, 10:22 AM
Stuwy123's Avatar
The front two and outside rear brackets line right up and bolt in.
For the fourth, you can either build a bracket or...
Swap the seat belt anchor with seat mount, to do this extend the seat bracket hole into a slot and get three washers per seat. Two underneath and one above and it will bolt in.
As for the center console, the 4Runner center console is mounted to the rear heater/ fan / A/C unit. I'm not sure if this will mount into the truck (i haven't tried) but the center console in the truck "should" mount right up. There are some holes under the carpet, where I "believe" the console will mount. I'm still on the lookout for a truck center console myself.
Old 05-22-2009, 11:55 AM
Hrddrvs's Avatar
Are you talking about 4runner seats or truck seats.Do truck seats fit right in with no problem?Are 4runner buckets different from truck buckets?Thanks.
Old 06-01-2009, 03:21 PM
Teuf's Avatar
i ditched the bench in my 88, got a nice set of grey cloth buckets out of a 4 runner sr5,
passenger side not in yet, my dog likes the space
Old 06-01-2009, 04:49 PM
aviator's Avatar
I recently did this same modification, 4runner buckets and truck buckets are identical. The difference come in in the seat tracks of the 60/40 and the driver's side bucket. You need to use the seatbelt mount bolt to secure the seat. And fill the old seat bolt hole with the old seat bolt. If you peal up the carpet you will see a round sticker covering the location where the factory bucket seat seatbelt would be bolted.
There is no body nut behind it though so you will need to either cut off a nut from another truck or use different hardware. [You cannot get the nuts from the dealer].
The bolts for the truck centre console are there covered by a rectangular sticker. You can see them from below attached to a bracket if you look above the transmission. Tap these carefully before you try to use them though as crud and corrosion will have fouled the threads by now.
Old 06-01-2009, 05:16 PM
fastkevman's Avatar
I did this swap last year with 4Runner buckets.
I agree with the above driver side seat belt info but, on mine the inner front hole for the driver side was there but the body nut wasn't tack welded there.
I had to cut a hole in the carpet and hold a nut under the seat with a needle-nose vise grip while turning the bolt in the front.......not easy by yourself.
I didn't anticipate this and it really, really sucked.
Also, the 4Runner and Pickup consoles appear to mount identically as I have a few "stacker" Pickup consoles and "heater" 4Runner consoles and I see no difference in mounting them.
What color is your interior? I have one "stacker" Pickup console that I want to get rid of.
Old 10-04-2009, 07:52 PM
alfio's Avatar
bringing this one back
i have a '92 with the 60/40 and i would like to go to buckets. two questions:
1) does the console from a similar generation 4runner bolt up (even if it has the fan for the rear heat) or is it too long for the extra cab?
2) what about third generation 4runner seats/console? anybody try that into a 89-95?
alfio
Old 10-04-2009, 07:57 PM
Stuwy123's Avatar
I'm holding out for a truck center console.
I've tried the earlier year's center console (pre-89) in my (post 89) truck and the holes don't line up and neither does the shifter leather boot.
Old 10-04-2009, 08:01 PM
alfio's Avatar
don't know if you've seen this thread but there's a guy running a tacoma console in his 89-95 extra cab, it looks good/very functional
alfio
Old 10-05-2009, 01:41 PM
aviator's Avatar
the one with the heater will work but the rear end would be loose unless you made a custom bracket, and you'd have to cut out the bottom of that shallow console to make it deep enough to be useful for anything...
Previous gen 84-88 won't line up 100% but might be usable with some reworking.
Old 10-21-2009, 06:59 PM
rhill's Avatar
anyone had any luck with buckets out of something other than a 4 runner or pickup?
Old 10-21-2009, 09:52 PM
aviator's Avatar
rhil man do a search here for bucket seats or bench to bucket seat swap, or something like that there are all kinds of threads on the topic...
People have, for example, swapped in Celica Supra sport seats, civic si buckets, Mustang Recaro seats, APC aftermarket buckets. It all depends how much fussing you want to do.
You can also switch seats from almost any 84 to current model year truck/runner the bases are almost all the same though the current runners seem to have a slightly different base and might be more trouble.
Old 10-22-2009, 06:57 PM
yotaman90's Avatar
Did the seats just drop in or did you have to mess with the bolt holes also?
Old 11-29-2009, 05:24 PM
Teuf's Avatar
I had to elongate the holes a bit to fit,on the outer side, easy do.
PNWrider
10-30-2015 08:14 AM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
Tigbucket
07-30-2015 07:29 PM
PureTacoma_Tundra
PureTacoma_Tundra
07-23-2015 11:20 AM
A2theK
07-12-2015 10:46 AM
Quick Reply: 60/40 bench to buckets question
