95 4runner door lock problem
Old May 23, 2009 | 04:00 PM
froggy's Avatar
First, Hello. Good stuff here.
My power door locks will not work right. I cannot hit "unlock" from the driver switch and it work. It will lock from that switch. The lock works fine from the pass. side and using the keys. I replaced the master switch. Same symptom.
Any ideas???
Thanks
Old May 23, 2009 | 06:56 PM
Jay351's Avatar
Are you getting power to the switch?
Old May 24, 2009 | 04:48 AM
froggy's Avatar
Yes, everything works except the ability to unlock from the master switch. It will lock from there, windows work. Just cant hit unlock and have it happen. Again this is a new switch I installed to fix the problem. It did not change a thing.
Old May 24, 2009 | 06:04 AM
froggy's Avatar
Was just looking at the tech manual. Looks like it might be the door lock control relay? Guess I'll have a look. Sounds like a pricey dealer item...
Old Jan 3, 2010 | 05:32 PM
CMD93's Avatar
Any resolution to this issue? I have the exact same issue and a new door lock switch did not correct it either.
Old Jan 4, 2010 | 04:00 AM
froggy's Avatar
No, got sidetracked on rebuilding the engine. Got that done now... still haven't messed with the lock but I am convinced it is the relay. Sorry I can not help more. Let me know if you try it and it works. I'll be looking for a relay soon.
Gamble_STi
Jun 27, 2015 07:54 PM
Outsane
Jun 24, 2015 05:52 PM
Lowviz
Jul 4, 2002 09:43 PM
