AC Compressor help
Old Apr 30, 2010 | 12:58 PM
BackGateYota92's Avatar
AC Compressor help
Hey there what ac compressor come stock in a 1992 3vze toyota pickup??? Was at the junkyard today and the guy said they had to types and to pop the hood and there should be a tag that tells ya but i see nothing. Thanks again and any help is appreciated
Old Apr 30, 2010 | 02:20 PM
Wheelingnoob's Avatar
He maybe referring to a R-12 or R-134a compressors. I think in 92-93 Toyota started changing them over to the more efficient R134a compressors. There should be a sticker on the hood stating if its R-12 or R134a.
Only other way to tell is looking at the fittings on the charge lines. R-12 has thread on fittings (looks like valves on your wheels) and R134a is a quick release like a air hose sort of.
Good Luck!
Old Apr 30, 2010 | 02:22 PM
alright thanks man. i looked on the hood sticker but its to old to read anything. ima try to find the fittings
Old Apr 30, 2010 | 02:30 PM
Both will be back by the fire wall were they go into the condenser right beside the Charcoal canister on the pass side.
Old Jul 6, 2010 | 03:27 PM
drtbklver's Avatar
AC Diagnostics - 93 toyota pickup 3.0
problem - AC compressor will not engage when the i hit the switch. I recently swapped out my 3.0 for a rebuilt and not just trying to get the AC dialed in, will the low pressure switch protect the compressor if there is nothing in the system? id like to ensure the system will run prior to adding the refrigerany (134a). How about the VSV? will this keep the compressor from kicking on or if the VSV is bad will it just keep the engine from kicking up slightly in idle? last question, will the thermistor prevent the compressor from kicking on some how? thanks for all the help . . .
Old Jul 6, 2010 | 04:47 PM
If there is nothing in the system the compressor will not turn on or engage. That's a fail safe if you lose the refrigerant and its oil that you will not burn up the expensive parts. As far as I know anyways, I always charge the system first and try from there.
Old Jul 6, 2010 | 05:05 PM
Tofer's Avatar
Sponsor
correct. there is a fail switch that is located behind the glove box. i still need to take mine apart to bypass it so my AC button turns on my OBA.
Old Jul 6, 2010 | 08:35 PM
drtbklver's Avatar
thanks for the info, is that the low pressure switch your talking about?
Old Jul 7, 2010 | 09:10 PM
drtbklver's Avatar
compressor is good, charged the system and everything kicked on like it should-- shut if off and turned it back on, my dad noticed a sputtering down at the compress, got underneth and found a large hole on the aluminum part of the low pressure line -- will the 4runner system match the 93, 4x4 3.0 V6? i checked my little bros 22re 93 and no dice-- the line ties into the cooling unit differently --any help?
Old Jul 9, 2010 | 08:52 AM
Not sure what you are asking? The system from the P/U will match the 4runner as long as its the same coolant type i.e. R12 system or R134a system.
Old Jul 12, 2010 | 12:15 PM
drtbklver's Avatar
Thanks for the help, I found that the 4 runner system matches the pickup system, ordered a new suction line from auto zone- thanks for the info . . .
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
coryc85
Dec 5, 2015 08:42 AM
JUICE222
Oct 13, 2015 08:50 AM
Badlander
Oct 10, 2015 08:05 PM
