A/C rebuild - input needed
Old May 3, 2010 | 06:10 PM
ahickman's Avatar
Looking for insight/advice on how to bring my A/C back from the dead. I bought an 87 Runner that has factory A/C, but some of the plumbing is missing. Actually it only looks like a single line is missing. Never the less, the compressor and lines have been exposed to air for some time. Looking for advice on how to determine if the A/C system is in good enough shape to recharge. I assume (after replacing the missing line), the system will need to be pumped down and leaks detected. Can only an A/C shop do this, or can I get a vacuum from Harbour Freight or other shop to pull vacuum? How do I determine if the compressor is in good shape? Any input is appreciated. I know next to nothing about A/C.
Thanks,
Aaron
Old May 3, 2010 | 06:27 PM
DeathCougar's Avatar
First thing I would check is the AC compressor. Make sure it isn't locked up.
Then go from there.
Old May 3, 2010 | 06:38 PM
ahickman's Avatar
DC, quick tutorial on what/how to check the compressor?
Old May 3, 2010 | 08:32 PM
Easiest way is to simply spin it. But make sure you are not just spinning the outer pulley, make sure you are spinning the compressor itself.
Old May 4, 2010 | 07:48 AM
myyota's Avatar
If the compressor has been sitting unused and open to the elements for a long period of time, then just replace it. The a/c compressor can and will go bad because of this, but who knows, you might get lucky and it might work ?.
Old May 4, 2010 | 05:37 PM
ahickman's Avatar
Other than the compressor, is there anything else that would be suspect after being exposed to air? How about the dryer?
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
HALMAN
Jun 14, 2002 09:02 PM
