idle speed adjustments?
Old Apr 22, 2010 | 06:12 AM
jwesty's Avatar
recently my idle speed dropped so i have been adjusting it to keep the rpms about 950. is it ok to adjust it? why would it be low?
Old Apr 22, 2010 | 06:17 AM
pwd's Avatar
pwd
Well my only thought is a possible vacuum leak. Best to search though, could be a lot of things. It should be fine to adjust it.
Old Apr 22, 2010 | 06:39 AM
rustypigeon's Avatar
950 seems a bit high. 750 for a manual and 850 for an auto.
Old Apr 22, 2010 | 11:43 AM
jwesty's Avatar
actually it's irregular, sometimes it'll be fine then others it's low and it seems like my engine is missing.
Old Apr 22, 2010 | 01:35 PM
Jay351's Avatar
Make sure you have no vacuum leaks.
Mine sometimes tends to idle lower when its really warm.. like after a long drive
Old Apr 22, 2010 | 08:11 PM
turborich's Avatar
Yeah, Mine will do the same thing after a long drive. Instead of the regular 850 it will be at around 650. Everything checks out good though so who knows?
Old Apr 22, 2010 | 08:14 PM
Jay351's Avatar
I have no clue, my girlfriends 95 22re 4runner does it too.
Ive given up... I just give it a little gas and make it idle higher. Ive had it go down to 200rpm, damn the cams sounded nice
Old Apr 22, 2010 | 08:34 PM
yotaman85's Avatar
https://www.yotatech.com/forums/f116...ecause-210191/
Old Apr 22, 2010 | 08:41 PM
leucopus's Avatar
Lightbulb
What year and make is your Yota and does it idle faster when it is cold and newly started then slow down when warm? If it starts with low idle, it could be your auxiliary air valve if you have an older Yota or your IACV "Idle Air Control Valve" if it's newer. This valve draws air into the intake until the vehicle warms up than closes when its warm. I have an 88 22re and my AAV was not retracting to the open position. It's idle was slow from the start and since it was still cold seemed to miss as well. Had to ride the pedal a bit to open the throttle body and give it some air til it warmed up. My valve is controlled by coolant and an electric heater coil both of which warm the valve and close it after it runs a bit. I have heard that some air valves are controlled by vacuum also but haven't seen one yet.
good luck!
Old Apr 23, 2010 | 06:25 AM
jwesty's Avatar
idles high when cold then the problem starts when it's warm. i'll pull up to a stop light and rpm fall way down but only sometimes.
Old Apr 27, 2010 | 10:01 AM
machine23's Avatar
i've got the same damned issue! i need to get my car smogged, but it wont pass because i have an erratic idle issue. and my engine also seems to miss as well. everyone is telling me it could be a vacuum leak. but ive searched and cant find one. so i need help too on this one
Old Apr 27, 2010 | 11:24 AM
jwesty's Avatar
mine is still doing it and doesn't seem to be running quite right either. the 3.0 is a piece of crap if you ask me.
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
