Loss of power in 4runner.
Old Apr 30, 2010 | 10:03 AM
robnkim's Avatar
Question Loss of power in 4runner.
I have a 94 4runner 3.0 4 wheel drive that is running bad. We bought two. The good one had a bad motor that appears to have been from a 90-91 model and a wrecked one, 94, with good motor.
We put on a new timing belt and seems to be in time. Ran good but started getting weak after awhile. Now it runs terrible and has no power. Drinking gas like a sponge on water.
Blew the return water hose. Had issues with the oil cooler on the drivers side lower part of the block when we first started the engine. Clogged. Seems that it has another issue with clogging, hence the hose.
We remove the MAF from the wrecked truck and replaced it. Not sure if that helped or not. We also replaced the hose going from the engine to the MAF. That seemed to help a little bit, but still didn't solve the problem. Plugs look fine, oil looks good. Loosing water at a slow rate, just sitting. It does great up to about 45, then it feels like I'm trying to pull my house down the road. I go 0 to 60 in 5.3.... MINUTES!
PLEASE HELP!!!
me-><--my 4runner
Old Apr 30, 2010 | 10:26 AM
OrRunner's Avatar
i would double check the timing, as far as the leak of water, maybe the water pump? had small water leak and it turned out to be the water pump going out, did the timing again while we were in there due to the runner feeling weak, and low and behold it just needed timing again...hope this helps a little!
Old May 4, 2010 | 01:25 PM
robnkim's Avatar
Thanks, we're rechecking that tonight. I'll post the results on it hopefully tonight or in the morning.
Old May 4, 2010 | 01:36 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
[QUOTE=robnkim;51434634] Drinking gas like a sponge on water.
Check the o2 sensor.....
Old May 4, 2010 | 01:37 PM
Old May 5, 2010 | 05:11 AM
robnkim's Avatar
We didn't get around to checking the timing last night, but still planning on doing it.
Would the o2 sensor trigger a code? Also how would I check it without replacing it?
Thanks!
Sleaker
Aug 26, 2020 06:03 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
gmonnie123
Jul 26, 2015 02:44 PM
