Is my engine dieing ?
Old Apr 25, 2010 | 01:52 AM
1993hiluxsr5's Avatar
Unhappy Is my engine dieing ?
Hi, i took my 1993 hilux out offorading today at landcruiser park and the 1st thing i noticed is that its hopeless.
it has an impressive lack of power, and its a 2.8D.
it was getting its ass kicked but a hyundi santa fe both on road and offroad, and the hyundi had no low range, road tires, no lift kit, and an auto gearbox 100% stock with a 2.2D 4 cylinder, so why does my hilux engine suck so bad ?
and is there any way other than a turbo to get more power out of it?
it was just depressing watching my car fail up every single hill, even in low range 1st gear, and a stock hyundi could do it with ease .
Old Apr 25, 2010 | 06:57 AM
old mud dog's Avatar
i would do a compretion test on the motor you should be 130 to 150 evenly across
a cyls .. other than that do you have a stock clutch if so that could very well be all
it needs something with a little more grab and have the flywheel turned a night an day diferance for few hundred bucks .
Old Apr 25, 2010 | 07:39 AM
Matt4Running's Avatar
Turning a flywheel is a waste of money,it cost 60$.I bought a new one for 115$.Why would anyone remove metal from a moving part on purpose to save 55$..?I have seen them on the net for even cheaper then what I paid for mine.
Old Apr 25, 2010 | 08:10 AM
swampfox's Avatar
it might not hurt to check the fuel and air filter. also the injectors could be needing cleaned.
Old Apr 25, 2010 | 08:12 AM
mattaway's Avatar
Where are you getting these prices from!? You got ripped... Last time I got mine turned it was $30, and I priced a new one for $75
Old Apr 25, 2010 | 02:19 PM
yeah i got a stock clutch but the clutch is fine, it grabs very well, its the engine that cant actually push the car along, let alone up hills
Old Apr 25, 2010 | 02:21 PM
what does turning the flywheel achieve ? power ? and all the air intake system is in mint condition and perfectly clean, i clean my filter lots, but not sure about the injectors.
i just dont understand how it can have no power at all
Old Apr 25, 2010 | 02:24 PM
vital22re's Avatar
totally a bro
you turn the fly wheel when replacing a clutch to remove hot spots and glazing from the surface. It gives the clutch a fresh surface to grab and holds better. Its the same reason why you resurface your rotors and drums.
Old Apr 25, 2010 | 02:37 PM
I was quoted 60$ for turning flywheel.I didnt get ripped on it because I bought a new one and yes Ive seen new flywheels from 47$ to 300$ online.Which brings me back to my original comment,why pay 30$ to turn it if you can get a new one for 75$..?
Old Apr 25, 2010 | 04:52 PM
it was an idea but if your sure the clutch is good look at the easy stuff feul presure
air intake .. or exaust assuming you have good spark an comprestion ..
these are all easy thing you can check at home in no time .....
and i turn fly wheels fo 20 bucks.. good new ones are 150 .. here in canada ..
Old Apr 25, 2010 | 05:07 PM
Red3.slow's Avatar
so your sure your problems came from lack of power and not lack of traction. I know my old 95 4runner had some problems with the vacuum lines for the ADD making me think 4WD was working when in fact is wasn't.
I know you said your where getting your butt kicked on the road. But that aside how does it feel, doesn't it feel how as compared to when you purchased it.
Old Apr 25, 2010 | 05:18 PM
allnmstkn313's Avatar
What's your compression like? Much blow by? Start simple. It was only built for 90 horse btw...
@Matt4Running - You pay 25-30 bucks to resurface a flywheel as a quality replacement is 10 times that. Cheap flywheels get smoked fast if you actually use the truck.
Old Apr 25, 2010 | 05:30 PM
yotaman85's Avatar
the 3L is a good motor but does no have allot of power. i think they were rated at 89hp and 135lbft of torque. a good flowing intake, exhaust and fuel timing will help allot. remember, the fuel pump is the best thing you can mod, it controls everything including timming.
Old Apr 25, 2010 | 11:51 PM
awdjunkies's Avatar
93Hilux where are you from? or better said, what country are you in? I thought the D in your 2.8D stood for Diesel which in turn means Turbo Diesel correct? unless you are in a different country which is probably why you are calling it a Hilux.
Old Apr 26, 2010 | 02:10 AM
oh no the car sticks like glue to everything, i was just dissapointed at the power, oh well im sure ill get used to it i guess :S but nothings broken right? it is just that slow ?
thanks for all the replys guys
Old Apr 26, 2010 | 02:25 AM
vital22re's Avatar
totally a bro
if if feels slow and sluggish, maybe you should think about regearing? tires may be too tall for your gearing.
Old Apr 26, 2010 | 09:47 AM
hunter4runner's Avatar
where are you that you have a 2.8D ?
Old Apr 26, 2010 | 03:17 PM
I got an OEM flywheel for 115$ and the 3.0 is rated @ 150HP not 89.
Old Apr 26, 2010 | 03:19 PM
its not a 3.0 its a diesel 2.8D
Old Apr 26, 2010 | 03:23 PM
Yotaman85 comment is what I was refering to.
