1990 efi bent arm
Old Apr 20, 2010 | 06:52 AM
proja123's Avatar
1990 efi bent arm
I have a 90 pick up with the 22 re I just put in out of a wrecked truck (front right corner) and have been having intermittent no start issues seems to be after warmed up tried different coil and igniter tried different ecu noticed last night that the rotating arm above the dashpot is bent a little towards the motor and the dashpot is broken trying to figure out if that's where my trouble is coming from or if I should concentrate somewhere else??? Also what's the opinion for using Bosch plugs ?
Old Apr 20, 2010 | 08:45 AM
DeathCougar's Avatar
Bosch plugs in a Toyota don't seem to work very well, and don't bother wasting your money on the fancy +4 junk plugs. A cheap Denso plug works perfect.
Also, define rotating arm? I seriously doubt that is the problem though, as it would cause it to not work all the time if there was a serious problem.
Old Apr 20, 2010 | 01:54 PM
allnmstkn313's Avatar
X2 on bosch plugs stinking, go NGK or Denso.
Rotating arm?
Old Apr 20, 2010 | 02:06 PM
proja123's Avatar
Let me rephrase its the piece that the throttle cable connects to controls the inside butterfly flapper again probably not the correct name also on the opposite side connects to the throttle position sensor
jb451
7
Oct 7, 2022 06:58 AM
Pocoyota
Sep 8, 2015 02:41 PM
gp66
Sep 7, 2015 08:29 AM
LJR
Sep 5, 2015 06:02 AM
Aaron Logan
Sep 3, 2015 08:08 AM
