snapped OFF SHOCK MOUNTING BOLT!!!!
Old Apr 24, 2010 | 02:19 AM
AKZEP69's Avatar
in process of removing left rear shock - upper mounting bolt - while doin a ZUK coil upgrade of rear leaf - over the 20+ years i've had this rig - have broke off bolts - extracted & or re-tapped threads - all good - but this one - what a $@#$^%&^ - couple hours trying - just no room to work - & i got lots o tools - just outta ideas -
Old Apr 24, 2010 | 05:30 AM
94xcab's Avatar
i broke off a lower bolt and welded a stud to it then used a nut and flat and lock washers. it has held up to over a year of use and abuse so far
Old Apr 25, 2010 | 08:19 AM
devldogs55's Avatar
Yup.. I'd weld a bolt on it and get it outta there.. then obviously replace it.
Old Apr 25, 2010 | 08:50 AM
Teuf's Avatar
Cut or grind off the mount, mount a new one.
Old May 22, 2010 | 03:30 AM
AKZEP69's Avatar
SHOCK bolt fix
upper left mount a #Q$ to get to .. so I found steel bushing with a set screw - drilled the mount .. longer set screw into mount itself .. tack welded face of bushing to mount..
Old May 22, 2010 | 03:45 AM
xxxtreme22r's Avatar
all that trouble, I woulda taken off the bed. lol
Old May 22, 2010 | 05:03 AM
Zelephant's Avatar
It's a 4runner, the bed don't come off easy lol!
Old May 22, 2010 | 06:03 AM
hahahah good point !!!!!
terminator
Jul 27, 2015 07:13 PM
SMOD
Jul 27, 2015 01:45 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
jon.r
Jul 11, 2015 03:34 PM
