No more street tires!
Old May 2, 2010 | 08:46 PM
toyota4x4907's Avatar
Just got my new to me mud tires mounted on the rig. They came with Nissan 6 lug rigs. The center holes were too small so I ground them out. Then the inner part was JUST barely too small to clear the drum and caliper Sooo i had to pay to get them on. Two Dunlop MudRovers and two BFG KM (guy claimed they were KM2 but I'm not sure, doesn't really matter though) 31x10.5 at about 50% tread fro $150. Mounting and balance was $90 since they had to take them off the Nissan rims. They are loud and can feel a little power loss for sure but look much better than the Uniroyal "All-Terrains" I had on it (31x10.5s) Next weekend I'll get to test them out
From this:
To this:
Dunlops:
BFGs:
Look at all those weights!! Doesn't shake at 45-60 now
Old May 2, 2010 | 09:42 PM
seanmearse's Avatar
Take it back to the tire shop. That many weights is not good. What would be done at the tire shop I used to work at, you would mark the tire, bust the bead and rotate it 90 degrees, then re-balance.
Old May 2, 2010 | 09:52 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
or put un-modified Toyota rims on it...
Sweet 4Runner BTW... You better be GLAD I haven't won the lottery yet... B/c I'd be on a plane with a boat load of cash to hand you for that thing...
Hold the Warn's though I'll let you keep those.
Old May 2, 2010 | 09:55 PM
4Yoter's Avatar
They put a lot of weights on one of my old rims cause it was bent that could be the case
Old May 2, 2010 | 09:56 PM
Why is it no good? It was at Sears. 10% off special since studs were supposed to be off on the 1st (I didnt have studs, but still got it)
Thanks Odds are if it was anything over $8K, I would take it. Preferably $10K-$12K
And they are just stock steal Toyota rims painted black.
Whats wrong with the Warns? They came already on the truck and havent had a problem with them in 10Ks. Eventually I will probably get AISINs, but there are more important matters to address. Them and the CB antenna mount are the only chrome on my rig.
Old May 6, 2010 | 04:46 PM
rattlewagon's Avatar
those are km1s. i say you should go bigger! but good score on the tires.
Old May 6, 2010 | 05:36 PM
tpaine14's Avatar
good lookin runner man. now...the action pics
Old May 7, 2010 | 02:48 AM
I was wanting to go 33x10.5, but I had to spend my regearing money on the head gasket issue. OH WELL!!!! 31s are fine with me
Action shots will probably be gotten on Saturday.
Old May 7, 2010 | 06:59 AM
yoder519's Avatar
yea those are the older BFGs. i got my set of older 35x12.50 BFG muds and one was wore unevenly really bad. they had a littel over 8lbs of weight on one. it rode horrible. then i got a diff set of tires fro that truck, and pu tthese on another set of used wheels unbalanced and they ride 10x better. looks good though!
Old May 7, 2010 | 12:07 PM
My truck feels 10x better with these tires on it. One of the BFGs is a little unevenly worn and a little more worn than the other one. Thats why I put them up front because I will have the hubs unlocked all summer except for when I'm wheelin. I think my truck feels better because it doesnt have this insane whobble-shake while driving now. And now I know it was a wheel. I was just about ready to start replacing U-joints.
Old May 8, 2010 | 12:56 AM
limon32's Avatar
Don't worry about those WARN hubs, mine came on my truck and I have tested them routinely (even in salt water) without fail. They're also a bit easier to take apart and maintain in my opinion.
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
39 Thieves
Jan 6, 2017 01:08 PM
Braparus
42
Jun 30, 2016 12:17 PM
DirtRoad93
Aug 23, 2015 05:50 AM
