whats the best fuel additive?
Old Apr 24, 2010 | 05:08 PM
YotANo0b's Avatar
From: live in arizona at this time.. intending to move to minneso-rusty-ta... hope my bed holds up! :P
1988 4WD V6 5spd... i want to use a fuel additive to clean the injectors n what not.. are they all a gimmick? i asked at the auto store which ones best and they said sea foam or a Lucas product... thanks for the help!
Old Apr 24, 2010 | 05:31 PM
myyota's Avatar
Sea Foam is the best in my opinion.
Old Apr 24, 2010 | 05:36 PM
vital22re's Avatar
totally a bro
sea foam, and marvel... but the best thing to do is pull the injectors and have them cleaned and tested at an injector specialty shop.
Old Apr 24, 2010 | 05:41 PM
Teuf's Avatar
no additive is the best one.
Old Apr 24, 2010 | 05:45 PM
yotaman85's Avatar
seafoam FTW
Old Apr 24, 2010 | 06:22 PM
moneyshot's Avatar
BG 44k. Hard to find, some dealers carry it. I've seen it work wonders!
Old Apr 24, 2010 | 06:37 PM
pruney81's Avatar
I've used seafoam in the gas tank. I have friends and people on here as well will recommend using it in the intake.
Old Apr 24, 2010 | 07:29 PM
Tracey98277's Avatar
i've never used sea foam but i've found that lucas does a good job at keeping the gunk out of the injectors and intake ports. i use it maybe once every 6 months.
Old Apr 24, 2010 | 08:39 PM
Tofer's Avatar
Sponsor
Old Apr 24, 2010 | 11:11 PM
CrazyEye's Avatar
Seafoam!
Old Apr 24, 2010 | 11:47 PM
94toy4x4fever's Avatar
agree with every one on seafoam that stuff works well! Also lucus. But best thing like the other guys said pull em and have them rebuilt!
Old Apr 24, 2010 | 11:59 PM
malteserunner's Avatar
I use Lucas.
On the other hand, I hear the NOS energy drink, pictured above, works wonders on GSXR engines....
Old Apr 25, 2010 | 05:54 AM
Blue_petersen77's Avatar
Seafoam.... in everything
Old Apr 25, 2010 | 06:46 AM
sportbiker929's Avatar
+1. works good
Old Apr 25, 2010 | 07:11 AM
Levis Pennae's Avatar
Yet another for Seafoam in everything, however you should plan on changing your oil and filter soon afterwords.
@Tofer: I love you.
Old Apr 25, 2010 | 08:03 AM
davo247d's Avatar
Originally Posted by Tofer
smart haha jk
Old Apr 25, 2010 | 02:40 PM
Myron's Avatar
seafoam is the best Ive used. Half can in crank half in engine with a full tank gas..then oil change as soon as you empty...you will notice the difference.
Old Apr 25, 2010 | 06:27 PM
tc's Avatar
tc
Either Seafoam or Lucas really smooth out the idle on my 3.0. Seems to run quieter (like less exhaust noise) too.
Old Apr 25, 2010 | 07:28 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
I've been pouring some off the shelf carb cleaner additive into my tank, but that's because I was having some hard starting in the winter that I ended up taking care of with some carb cleaner spray on a gummed up throttle. Haven't really finished the present tank of gas off yet, but it has been running a little nicer as the tank's gone on (somehow it's kept the gas from going bad over several months). Really I think I just need to rebuild my carb and change the fuel filter, but I'm lazy and have other things to take care of first and this helped do the trick. Don't know if it'd be okay using the same stuff in an EFI equipped vehicle, but I'd probably avoid it just because it's meant for carbs and not injectors (last thing I want to do is give someone advice that fouls those stupid little needle valves).
Old Apr 26, 2010 | 12:15 AM
awdjunkies's Avatar
@Tofer: I love you.
+1 as well as plugs (In addition to the oil/filter).
