whats the best fuel additive?
From: live in arizona at this time.. intending to move to minneso-rusty-ta... hope my bed holds up! :P
1988 4WD V6 5spd... i want to use a fuel additive to clean the injectors n what not.. are they all a gimmick? i asked at the auto store which ones best and they said sea foam or a Lucas product... thanks for the help!
i've never used sea foam but i've found that lucas does a good job at keeping the gunk out of the injectors and intake ports. i use it maybe once every 6 months.
From: Downtown Heckronto, Ontario, Soviet Canuckistan
I've been pouring some off the shelf carb cleaner additive into my tank, but that's because I was having some hard starting in the winter that I ended up taking care of with some carb cleaner spray on a gummed up throttle. Haven't really finished the present tank of gas off yet, but it has been running a little nicer as the tank's gone on (somehow it's kept the gas from going bad over several months). Really I think I just need to rebuild my carb and change the fuel filter, but I'm lazy and have other things to take care of first and this helped do the trick. Don't know if it'd be okay using the same stuff in an EFI equipped vehicle, but I'd probably avoid it just because it's meant for carbs and not injectors (last thing I want to do is give someone advice that fouls those stupid little needle valves).
haha jk
