86 4runner keeps dying/ rough idle
Old Apr 25, 2010 | 08:07 PM
Jcurtisward's Avatar
Hey everyone,
I'm very new to toyotas and 4x4. Just bought an 86 4runner but I'm having some problems with it. It idles rough, and when I'm driving down the road it'll sometimes die when I let off the gas. Also it's idleing at about 900-1000 and I heard it was supposed to be at 700. One more problem is the truck failed emissons for everything.
So far the only problem I see on the engine is the rubber part on the intake is cracked. So I've taped that up and am ordering a new one tomorrow.
The engine is supposed to only have about 20k on it.
please help!
Old Apr 25, 2010 | 08:12 PM
SoCal4Running's Avatar
Well first I would pull the plugs and do a compression test.
After that a complete tune up including valve adjustment and inspecting the O2 sensor.
Replace all the vacuum hoses per the diagram under the hood and also test the TPS
With a new to you used vehicle you kinda need to start at the beginning and check EVERYTHING.
Old Apr 26, 2010 | 05:09 AM
Ok, i'll look into all that. would the cat have any impact on the way it runs?
Old Apr 26, 2010 | 11:06 AM
Ok just checked to codes on lunch, I'm getting 5 (oxygen sensor) and 11 ( something to do with the tps) any help is appreciated.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
