electrical: battery or alternator or other??
Old Oct 12, 2009 | 05:39 PM
blue_CA_yota's Avatar
I've noticed over the past week that randomly when I hit the brakes, the radio would turn off quickly and turn right back on. I dismissed it as a lose connection in my radio..
Today while driving, i turned on the blower motor and the truck died, but immediately bump started itself.. All lights, radio, blower motor clearly stop for 1/2 second then come back when the motor kicks back on..
I am going to test the battery for volts at idle, and if its good, I'll bring the alternator into Parts Source for a free test..
Looking for some insight before I get my hands dirty, its pretty cold outside.
Old Oct 12, 2009 | 05:43 PM
iamsuperbleeder's Avatar
hmmm
sounds like maybe a bad alternator (or more specifically, a diode or the regulator in it)
any lights on the dash lit? like the battery and brake lights maybe?
most parts stores can load test the battery and alternator while still in the truck btw
Old Oct 12, 2009 | 05:46 PM
i'll look into in-vehicle testing..
I wasn't sure if it was a voltage regulator in the alt, or if my battery wasn't handling the spikes well..
Old Oct 12, 2009 | 06:18 PM
ak4rnr's Avatar
Check out the following thread and see if this might be your issue:
https://www.yotatech.com/forums/f116...rite-up-33526/
I know the thread deals with a 1995 4Runner V6, but it might be a way to check one more thing off the list during troubleshooting. The radio in my 2nd gen 4runner would cut out for a second or so when I hit the brakes. After doing the electrical connection improvement between the pos. terminal of the battery and the 80A fuse it did the trick. No more power loss during braking!
Hope this helps.
Old Oct 12, 2009 | 06:29 PM
ericz's Avatar
When I had alternator troubles out of my 93 the first symptoms were radio related. I didn't notice any specific correlation between the brake lights and the radio but the radio would always drop out when switching on the head lights, rolling down the back glass, or during any other kind of high amperage draw. The alternator was a World Class brand reman (on the truck when I bought it) and is but one of MANY World Class alts that I have seen fail.
Old Oct 12, 2009 | 06:43 PM
Hope this helps.
Great link! Sounds exactly like what my truck is doing.
I will take a look at my truck tomorrow.
Old Oct 13, 2009 | 02:22 PM
Here is what my cable looked like
Here is a closeup on the battery end.. Only 4 strands were holding on when I took it off, but they broke when I bent the eye connector back and forth twice..
At idle, I turned on all my lights, radio loud, and heater.. so far it's all holding together.. I won't know for sure till I go for a drive..
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 4, 2015 11:30 AM
bradahman
Oct 1, 2015 09:24 AM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
