replacing exaust manifold gaskets... will I need new studs?
Old Oct 13, 2009 | 10:55 AM
rustypigeon's Avatar
Hey gang. I have an exhaust leak at the #4 cylinder in my 94 22re. I ordered the new gaskets and the 8 nuts that thread onto the studs. I am wondering how well the studs will look after I pull the manifold off.
Are the studs reusable, or will they be rusted and stripped by the time I get the nuts off?
Old Oct 13, 2009 | 10:57 AM
Lumpy's Avatar
Should be fine...PB Blaster is your friend. But it depends on how rusty things are. On my 92 they came apart just fine with a good soaking.
Old Oct 13, 2009 | 12:34 PM
Thanks. I'll be soaking them in PB tonight, the parts won't arrive until the morning.
Does the gasket usually come off the head and manifold easily? Or will there be a lot of scraping involved?
Old Oct 13, 2009 | 12:39 PM
Lumpy's Avatar
It should be a metal gasket and just pop right off...
Old Oct 14, 2009 | 11:09 AM
Manifold is off and at the machine shop. $75 to resurface the manifold. It was well beyond the .029" warp limit. They will charge me by the hour to pull the broken stud out of the manifold. I have to wait until tommorow to get the new head pipe studs to finish the job. All the manifold to head bolts came out easily. The manifold to head pipe bolts were all seized, despite using anti-seize the last time I put them on a few years ago.
Old Oct 17, 2009 | 06:23 PM
Stuwy123's Avatar
I suggest you replace them all.
I know it sounds excessive but when I took mine off, half the bolts were rusted, pitted and starting to wear badly.
Keep the old nuts so you can tighten the new studs in.
Remember the longer bolts go in the top and the shorter ones go on the bottom.
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
87blyota
Jul 10, 2015 04:31 AM
