*sigh* What is a code 43 on a 22re?
Old Oct 9, 2009 | 03:51 PM
Junkers88's Avatar
I looked and looked and everyone that had a CEL code 43 had a 3.0 and it came back as an ignition issue, is it the same on a 22re?
You know it just freaking figures that this is the weekend I plan on fixing the IACV, doing the brakes, fluid change etc and now this damn CEL pops up. I have a code 43 (see above) and 71 (EGR...... again).
On a good note though I did retime the little beast and that odd little miss at idle has gone away. One down, fifteen hundred to go.
Old Oct 9, 2009 | 03:54 PM
89silverpu's Avatar
Appears to be the same:
STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
--IGNITION SWITCH/CIRCUIT
--ECU
From here:
http://www.off-road.com/toyota/tech/codes/index.html
Old Oct 9, 2009 | 03:56 PM
Lumpy's Avatar
Well you probably have the same list I have but here is the link.
43 = Starter signal
http://www.troublecodes.net/Toyota/
Maybe check some grounds and or some of the connectors in and about.
Old Oct 9, 2009 | 04:12 PM
yoterr's Avatar
lol that sucks, and you JUST posted about not starting threads lol, if it makes you feel better i just figured out that a weird vibration that ive been having when letting off the throttle was a loose pinion nut theres fluid everywhere, hopefully the gears are ok..
Old Oct 9, 2009 | 05:25 PM
BigBluePile's Avatar
See, I just don't have those problems...huh. Wierd.
Old Oct 9, 2009 | 06:26 PM
sb5walker's Avatar
43 is usually a phantom - happens once and for seemingly no reason. If there really wasn't an STA signal at the ecu, the circuit opening relay wouldn't power the pump while cranking and it wouldn't start. So unless it keeps recurring, I'd ignore it.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
Jul 24, 2015 06:29 PM
jake_v
Jul 22, 2015 03:17 PM
