Front Differential Swap
Old Oct 8, 2009 | 09:43 AM
UpInSm0kE's Avatar
I need some help. I have swapped both my front and rear gears to Factory 4:88's. The front seems to be giving me some problems. I have swapped over my old axle tube and axle shaft from my 4:10 carrier (Non-ADD) to the 4:88 (ADD) carrier. I am wondering is this ok to do or am I gonna have problems with the Driver Side seal not sealing? I am all confused because the seal is in 2 different places on the drivers side for ADD and Non ADD. Can I just buy new seals and put them in without using the ADD equipment? Thanks in advance!
Old Oct 8, 2009 | 10:32 AM
DeathCougar's Avatar
I am confused myself....all you have to do is switch the jack shafts from one to the other. Same end seals.
Old Oct 8, 2009 | 10:47 AM
UpInSm0kE's Avatar
Sorry for the confusion. I have already pulled the front diff twice now so im a little flustered. The axle shaft seal on the driver side keeps leaking. I am just wondering are the differentials exactly the same just different axle tubes? The seal that keeps leaking is the one on the drivers side. This is the side that I swapped the axle tubes is this ok?
Old Oct 8, 2009 | 11:24 AM
The front diff center section is the exact same, once you remove the ADD stub axle, and drive gear stub.
Old Oct 8, 2009 | 11:36 AM
swapped89's Avatar
use silicone
Old Oct 8, 2009 | 12:04 PM
and how, praytell, do you suggest he uses silicone to seal an axle shaft?
Old Oct 8, 2009 | 12:39 PM
Junkers88's Avatar
indeed.
Old Oct 8, 2009 | 02:13 PM
iamsuperbleeder's Avatar
lol, ummmmm, a LOT of it globbed up eveywhere?
lol, I laugh, but you know there's got to be SOMEONE out there who's actually tried that before
Old Oct 8, 2009 | 02:35 PM
That stuff will seal ANYTHING!
Old Oct 8, 2009 | 02:41 PM
Kiroshu's Avatar
^lol!
Old Oct 8, 2009 | 02:42 PM
camo31_10.50's Avatar
LMAO!!!!!!!!
of course i would like to know all of the problems people encounter when switchin from stock gears to factory 4.88's..lol
Old Oct 8, 2009 | 02:44 PM
Kiroshu's Avatar
Once you take away OEM it will never be right again....
Old Oct 8, 2009 | 04:23 PM
Junkers88's Avatar
That is probably what Kid Rock said when he started dating Pam.........
Old Oct 8, 2009 | 06:57 PM
lmfao
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
AaronM
Jul 8, 2015 07:15 PM
toyoda8488
Jul 5, 2015 10:18 PM
